Old 06-04-2019, 10:30 AM
streamingtheatre streamingtheatre is offline
Default Eucon 19.5.1 is out now
Eucon 19.5.1 is out now...
Old 06-04-2019, 07:48 PM
MoPro's Avatar
MoPro MoPro is offline
Default Re: Eucon 19.5.1 is out now
You first!
Computer Asus P9X79 Deluxe | Intel i7 3930k | 32 Gig Ram | Intel 520 SSD's | 2T Caviar Black
Software Win 7 Ultimate (64bit) | Cubase Pro 9.5.41 (64bit) | WaveLab 9.5.25 (64bit) | HALion 6 (64bit)
Hardware RME FireFace's UFX / 800 | MOTU MTP AV USB | Avid Artist Series: Control, Mix, and Transport | EuControl ver. 18.3
Old 06-04-2019, 09:28 PM
BScout BScout is offline
19.5.1 fixes things that people on the forums were complaining about. It's a safe bet.
Pro Tools Ult 2019.6, HDX 3, MTRX/SPQ, HD Omni • Mac Pro 5,1 - 3.06 GHz 12 core - macOS 10.13.6 • RAM 64GB, SSD 4 x 2TB, GPU GTX 980 4GB
Old 06-05-2019, 03:47 AM
"Navigating in the Pro Tools Edit window using the “p” or “;” keys could fail to maintain track Attention and/or window focus (GWSW-12433)"
I tried this but it only seems to work for plugin windows and the pan window. Sends however just close when you move to the next track.
F.
PTHDn 2019.6 (OSX10.14.4), 8x8x8, MacPro 5,1 3.33Ghz 12-Core, BM DeckLink SDI, SYNC HD, all genlocked via AJA GEN10, 48GB RAM
Old 06-05-2019, 09:43 AM
EddieJones's Avatar
F.
Correct, this is because send windows work differently, may not be there or maybe a different one.
Old 06-06-2019, 06:17 AM
Thanks, at the moment it closes even when it's the same slot sending to the same bus. Keeping it open would indeed help for example when you're trying to apply some reverb to 5 tracks on elements belonging to the same effect in a film session. In that case you'd have sends in slots 1-3 unified across a whole set of tracks for example.
Maybe the send can close if the send in a given slot on the next track is going to a different bus to signal it's a different effect you'd be sending to.
Thanks
Frank
Old 06-08-2019, 11:43 AM
What’s Fixed in EUCON 19.5.1
S6
• Some S6 M10 system licenses could fail after upgrading to v19.5 (GWSW-12430)
• VCA bus knobs could fail to update displayed values (PT-251990)
Requires Pro Tools 2019.6
All EuControl Devices (S3, Dock, Pro Tools | Control, and Artist Series) and EuControl Software
• EuControl: Soft Keys for Pro Tools could fail to import into v19.5 (GWSW-12432)
• On macOS Mojave, text such as application names could appear upside down (GWSW-12442)
• Pro Tools | Control could fail to accurately indicate workstation connection status when focused on a non-EUCON application
(GWSW-12441)
• Layouts could fail to be saved as expected (GWSW-12455)
• It was possible for windows to open and close (or not) in an undesirable fashion when using the Attention and Open Window settings added in v19.5. See Open Windows on Workstation Attention.
• S3 and Mix: OLEDs could fail to update (GWSW-12431)
• S3: Plug-in and Send windows could fail to close after navigating back to the top level Inserts or Sends view (GWSW-12456)
• Adding or deleting tracks in Cubase or Nuendo could appear to freeze and blank out surfaces (GWSW-12466)
• MackieControl could fail to load if auto-started by EUCON Preferences on macOS (GWSW-12443)
• An appset has been added for Calendar on macOS
All Systems:
• Show Momentary Fader Values could fail to show parameter values as it had in previous versions (GWSW-12427,
GWSW-12438)
To improve Momentary Fader Value display, new options have been added to support the Fader Value Timeout slider. See
Improved Momentary Fader Value Display.
• Navigating in the Pro Tools Edit window using the “p” or “;” keys could fail to maintain track Attention and/or window focus
(GWSW-12433)
• Functions not set to open windows could fail to close windows (GWSW-12453)
Requires PT 19.6
No word on any fix for Cubase.
Guy Rowland
www.guyrowland.co.uk
PT 2018HD; W10 Pro; i7 7820X; 64gb RAM; RME Babyface; UAD Quad Satellite USB; GTX 1050i
Old 06-08-2019, 11:54 AM
EddieJones's Avatar
• Adding or deleting tracks in Cubase or Nuendo could appear to freeze and blank out surfaces (GWSW-12466) ?
Old 06-08-2019, 11:53 PM
ALSTUDIOS ALSTUDIOS is offline
Hi
Yes, confirm, that this problem has been resolved.
Cheers
ALSTUDIOS REGENSDORF SWITZERLAND
a.l.recordingstudio.ch@gmail.com
https://sites.google.com/site/alrecordingstudio/
1pc AVID Artist Control and 1pc Euphonix MC Mix
Win7 64Bit, Cubase Pro 10.0.20
Old 06-09-2019, 05:45 AM
I'm blind! Thanks folks, I'll give it a try here.
Guy Rowland
Updated to Eucon 3.6 and lost all my custom Eucon commands bassmagnetic Pro Tools | S3 0 04-18-2017 10:09 AM
EuCon suddenly broken - Eucon client can not access the bonjour service noiseboyuk Artist Series 0 04-12-2016 12:34 PM
Eucon 3.2.2 installer error + firmware downwards compatible with eucon 3.1 deauditievedienst Artist Series 0 08-05-2015 02:09 AM
EUCON 2_6_1 eucon discovery cant find ip klaukholm System 5 2 10-22-2011 12:01 PM
