massive 002 problems
What the heck is going on? When I first loaded Pro Tools 6, everything was fine. The next time I booted up PT, the Digi waited in standby, and then shutdown with only a few lights on but no response.
I thought there was a command in LE or something to turn on the Digi 002 but there isn't. I booted PT back up and got some updated firmware. It worked once more and then did the same thing, no response. So I completely reloaded PT, and it worked the first time as it did before. I then exited PT to test it out and rebooted. I didn't get a firmware update message but after PT loaded, my 002 came out of standby with only the welcome message on it. No buttons worked and I could get no response. I could still play the audio signal through it though. What the heck is going on? This thing is suppose to communicate with PT on the spot. I have connected and reconnected everything. Any suggestions??? adam
PT LE 6.4cs9 Digi 002 Dual Mac G4 OS X Panther |
Re: massive 002 problems
Read the thread called 002 MALFUNCTION!
A bunch of us had this kind of thing going on; we traded our units in (seems they had a bad batch) and all seems to be well. The only thing you need 'hooked up' is a FireWire cable to your Mac and PTLE 6.0.2.
iMac (Retina 5K, 27-inch, 2020) OSX 12.7 PT 2024 |
Massive Horsepower problems... | sventvkg | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 07-30-2010 11:44 AM |
Massive CPU Peaks, serious problems... | XsuspendedX | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 04-25-2010 04:41 AM |
PT 7.3 any problems using Massive Pack 5 .....ETC | AMIEL | Pro Tools TDM Systems (Mac) | 0 | 12-07-2006 05:15 AM |
Massive Problems Please Help!!! | N@W | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 06-17-2006 07:55 AM |
Massive problems | David Schober | Pro Tools TDM Systems (Mac) | 7 | 02-08-2006 01:08 AM |
