Import Track Inserts feature
Loving the recall features. Would like to see it go a step further and be able to import inserts from tracks in other sessions. Currently to do this you have to use import track date and import the entire track, then drag the inserts you want to the desired track (takes even longer with UAD plugins).
The purpose of this is because I often want to reuse a chain if doing a couple jobs for the same client, but don't necessarily want every chain saved as an actual preset. Go to an insert slot, pull up the inserts menu, and have an option that says Import Track Inserts. This feature would allow that.
www.HellfireBeats.com UAD 2 Apollo Quad w/Thunderbolt 3, UAD 2 Satellite Octo TB3, UAD 2 Octo PCIe, Avid S1, Neve R6 500 Chasis, Neve Portico 511, Neve Portico 551, Dangerous DBox+, Focal Trio6 Be, Neumann TLM49, Akai MPC 2000XL, Akai MPC X, Mackie 1202VLZ Pro, Akai Advance 61 Pro Tools 2021.12 Mac Pro 7,1 2019, 8 Core, 48GB RAM - MacOS 11.6.2 16" MacBook Pro 2021, M1 Pro, 16GB RAM - MacOS 12.1 27" iMac, Late-2012, 3.4GHz i7, 24GB RAM - MacOS 10.15 Last edited by DJ Hellfire; 05-06-2018 at 07:55 AM. |
Re: Import Track Inserts feature
Why not just use "Import Session Data" but only check "Plug-in Assignments" and "Plug-in Settings and Automation"?
Because you still have to import the entire channel and drag the inserts over to your new channel. Import Session Data applies to your entire session. What I'm suggesting should be done at the actual track. Go to an insert slot, pull up the inserts menu, and have an option that says Import Track Inserts.
www.HellfireBeats.com UAD 2 Apollo Quad w/Thunderbolt 3, UAD 2 Satellite Octo TB3, UAD 2 Octo PCIe, Avid S1, Neve R6 500 Chasis, Neve Portico 511, Neve Portico 551, Dangerous DBox+, Focal Trio6 Be, Neumann TLM49, Akai MPC 2000XL, Akai MPC X, Mackie 1202VLZ Pro, Akai Advance 61 Pro Tools 2021.12 Mac Pro 7,1 2019, 8 Core, 48GB RAM - MacOS 11.6.2 16" MacBook Pro 2021, M1 Pro, 16GB RAM - MacOS 12.1 27" iMac, Late-2012, 3.4GHz i7, 24GB RAM - MacOS 10.15 |
You can import just the plugins for any particular track from one session and lay them into a specific track. Instead of importing as New Track, use the drop down list to select the track in the current session you want to import the data onto. |
But I still think this could be made more efficient with my suggestion, although it would technically be duplicating existing functionality.
Actually, I was correct in my original statement. When you are trying to import inserts from different track types, you have to import the entire channel and drag the inserts. Example, if I want to import inserts from a Master channel to an Audio channel, the Import Session Data menu does not allow you to select your audio channel as the track to import your Master channel data to. You can only select option New Track unless you are importing to another Master channel. The same is true if trying to import from an Aux channel to an Audio channel. So again, would be nice to have a feature to import track inserts from another session.
Feature request -post fader inserts on tracks/aux | Sonsey | Post - Surround - Video | 15 | 07-13-2018 08:22 PM |
Import track or session files ? And Import, then SAVE ? | theivories | Pro Tools 11 | 1 | 09-25-2015 07:36 PM |
PT 9 I/O setup import/export/ bug? feature?? | AMP Studios | Pro Tools TDM Systems (Mac) | 8 | 07-01-2011 06:17 PM |
Feature request - 32 bit audio import | digidesigner | Pro Tools TDM Systems (Mac) | 14 | 04-27-2009 06:49 AM |
looks like no import feature for PT 6.0 LE | Calvin | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 01-21-2003 08:21 PM |
