Old 04-21-2014, 11:10 PM
ghengus23 ghengus23 is offline
Default ASIO4ALL help
I recently used ASIO4ALL to be able to run PT11 on my Laptop with WINDOWS 8. Unfortunately, I cannot use the laptop's input jack to record. Might anyone be able to assist with this? Is it possible to use the laptop's internal sound card for recording audio?
Old 04-21-2014, 11:20 PM
Default Re: ASIO4ALL help
You really need to describe more clearly what you are trying to do. What exact laptop. What exact input? if a Microphone what exact mic. What exactly is plugged into what with what cable, etc. A Sandra report might help. Posting screenshots of your ASIO4ALL config screens, and Pro Tools IO input tab definitely would. And what exactly happens when you try to do this? Start at the "Help us Help You - READ THIS Before Posting!" above on this Web page.
Old 04-22-2014, 03:46 AM
ChuckS ChuckS is online now
Just a quick guess - if you didn't install the ASIO4ALL Offline Settings app when installing the driver, install that. It's easier to use than changing the settings when ASIO4ALL is running with PT. Open the offline settings app and to get the expanded configuration click on the wrench. Then you can select which inputs and outputs from your onboard audio device that will be presented by ASIO4ALL, i.e. mine is IDT and you can select the line in and/or the mic for input(s).
PT 2024.3 DP 11.31 VEP 7.x with various VIs
NI Komplete Audio 6 on HP Envy 8G i7 Quad Laptop Win11
MOTU 828es ADA8200 MTP-AV on HP Z2 G4 Xeon Workstation Win11
MOTU M4 on MacBook Air M2 2023 Sonoma.4.1
Asio4All Red X GrantJensen FireWire & USB Audio Interfaces (Win) 7 09-21-2013 04:24 PM
Will ASIO4ALL let me do this...? Dufo Windows 3 05-21-2013 10:16 PM
ASIO4ALL - Unavailable?? Wyn Windows 2 09-05-2011 05:41 AM
ASIO4ALL vs 003 monitor o/p SEPTICTHRASH Windows 2 06-18-2011 07:39 PM
Asio4all Aussie169 Pro Tools 9 4 11-30-2010 02:33 PM
