Windows users with CPU spikes/errors 12.5
I'm looking for Windows users who have CPU errors/spikes on 12.5
Could you do a quick test to see if this helps: Use the Task Manager to set processor affinity for ProTools.exe, and de-select a couple of processors. On the systems I've tested on, all CPU issues go away. I'm trying to see if this workaround works for others. Open Task Manager (Click More Details if it doesn't show the Details tab.) Select the Details tab scroll to find ProTools.exe then right-click it and then click Set Affinity. de-select a processor or two, then click Ok. Does the CPU levels in the System Usage (in ProTools) window calm down? |
Re: Windows users with CPU spikes/errors 12.5
I tried this a couple of days ago (disabling the last two processors), and the spikes still returned. FYI Avid support did not have any solution for me regarding this so far.
For Windows7 PT12.3.1 is The best so far,
Anyway... I did the set affinity and the results were dissapointing, because affinity does not tell PT it has less cores, only removes cores from PT. Avid should have or include a command line option like VSTHost.exe /numprocessors=20 For example... http://protools.ideascale.com/a/dtd/...es/237816-3779 If set affinity could be forced Before PT detects the # cores, that could be useful. After is useless.
--->If you don't like what i wrote: Click: JuanPC Click: View Public Profile Click: User lists^ Click: Add to ignore list. Solved. |
I tried this on an 8-core I7 CPU with hyperthreading disabled, and it did not stop the -9173 error from occurring. OS was Windows 7 SP1, PT version 12.5 w/HDX.
I've yet to see if it makes any difference with hyperthreading on. One observation I've made is, that with more cores showing due to hyperthreading being enabled, the reported CPU usage is lower. Also, based on what clock speed I run, the usage will decrease with a higher clock speed as well. |
i upgraded to 12.5 but i couldnt get pt to open so i went back to 12.4 and now its saying "MSCVR120.DLL" is missing. i cant open certain plugns such as varifi or pitch shift, i dont know what to do.
You have a bad install. Download the installer again.
pro-tools-pc.com TRASHER Pro Tools Utility(updated 4-11-2024) HD Native, Avid 16x16, Eleven Rack, Focusrite Clarett 8preX, UA Quad Apollo TB. Intel I7 9900k Win 10 |
should i uninstall pt and all of its components then re install?
Yes, but be sure to re download the installer.
Thanks alot
Ilya Efimov Users CPU Spikes | Becharax | Virtual Instruments | 0 | 04-15-2015 11:35 PM |
Speakerphone CPU Spikes after upgrade to Windows 8.1 | seanmccoy | Pro Tools 10 | 0 | 08-14-2014 11:01 AM |
CPU Spikes/Buffer Errors Tracking at 96K 10.3.6 | sws2h | Pro Tools 10 | 4 | 07-16-2013 04:56 PM |
Pro Tools System Usage CPU monitor Spikes but not Windows | Sherbert99 | Pro Tools M-Powered (Win) | 0 | 05-28-2008 07:18 PM |
Are Windows users seeing the same bugs as Mac users? | poly915 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 14 | 08-11-2007 07:51 PM |
