#21
Re: Yosemite support is now available with EuControl 3.2.2 and Workstation 3.2.2!
On my 2 systems on Yosemite, the Transport was claimed and updated right away, but each mix system didn't want to be claimed. After numerous restarts and following the troubleshooting directions on system 1 with no success, I left the system for an hour. When I came back, the mix had been claimed, and the update was successful.
The next day on system 2 I had the same issue with the mix not being claimed, so I ignored it and worked for an hour, checked again, and it was claimed, and updated successfully. Looks like if you just ignore it for a while, it will eventually be claimed and you can continue. Hope this helps. |
#22
This also applies to women.
#23
We tried to reproduce the Logic issue in-house and can't. What version of Logic and OS are your using? Does this happen on a brand new Logic project with only one track? Does it happen every time? Is there another thread or IdeaScale bug I can reference for more info? Maybe the Save Soft Keys bug didn't annoy you, but it was annoying to other users so we fixed it. In your opinion, what are 3 bugs we haven't fixed that you think are top priority? Thanks,
Kyle Splittgerber Senior Principal Product Designer Avid Berkeley, CA |
#24
Hey Guys,
Thanks for providing feedback on your experiences with updating firmware. It definitely can be a bit challenging because its essentially all about timing. Either the timing will be right and surface will be recognized and attach, or it won't. Some additional advice for those having trouble:
#25
#1. This started after Eucon version 2.6.2, something was changed after this. When I turn the jog wheel, on both transport and MC control, it always snaps to the nearest bar and is never more precise than that. Not so good for nudging and stuff. #2. Shift-fader touch no longer snaps to 0.. I think this is more recent, others have complained about it too. #3. When track stacks were introduced in Logic X, Eucon has no idea how to deal with them. I'm talking about layouts. Create a layout with everything blanked but 4 faders for example. Now create a folder stack or summing stack with these 4 and the static locked faders turn back into "auto assigned".. messes everything up if you prefer to work without banking. As for the missing plugin display, that broke a few versions ago too. It doesn't happen every time, but I have come up with a reliable way to reproduce it for you in the next message. My version of Logic is 10.1.1 and I'm running OS X 10.10.2 Finally, and this is more of a redesign issue. All of the knobs are very much useless because they are not linear. The ideascale URL that explains this best is here: http://protools.ideascale.com/a/dtd/...bs/129794-3779 That's a big one for me, probably the most important in my view. |
#26
To reproduce the bug:
Start with an empty logic project. Create 1 audio track, select it. Enter insert config mode on the Mix. Pick Insert 1 > Delay > St Delay > Stereo Leave config mode. You will notice that the green ON light is lit, but no plugin name is displayed on the surface.. please confirm. |
#27
Don't worry, this is coming in 11.3.2.
#28
#29
Also, we were able to reproduce the Logic issue and will investigate further.
#30
I'd like to chime in on this as well... I hope you would have more time to look in to the issue now that Yosemite support is officially done?
Eucontrol for Yosemite?? | bjkiwi57 | Artist Series | 7 | 04-24-2015 06:08 PM |
EuControl v3.2.1 and Workstation v3.2.1 Release | Kyle Splittgerber | Technical Alerts | 0 | 11-20-2014 01:19 PM |
