Mixing and mastering with a two track instrumental
I have been recording a lot of hip hop music for the past month. Most of the artist come to the studio with a two track mixed version of the instrumental instead of the separated instruments and they want me to record their voices individually with Pro tools 7.1. I dont have any problem with that, but I do know there is nothing like mixing the individual instrumental tracks with the voices. 80% of the two tracks that are brought in are of good sound quality and the spacing of the instruments is ok.
Would anyone have any helpfull tips that I can use to make the music sound as professional as it can with just the two track beat and the separated voices? I am currently using the Waves Renn maxx, SSL 4000, and the Digidesign plugins to mix the recordings. Any advice will be greatly appreciated, Thank you |
Re: Mixing and mastering with a two track instrumental
i'm not no rocket scientist but i do a lot of the same stuff/
for starters u could just flat out eq the 2 track compression etc..... then to the best of your abilty do the same to your vox.... use your earrrrrrrrrssssssssss!!!!!!!! yung skool |
What you need is are two examples, one from each method. Make sure the multi-track mix stands out as far superior to the 2-track plus overdubs. You can use the same song, or choose a better song with better vocals and a great mix with all the bells and whistles. Then, let the artist "decide" to bring you the multi-track beat. IOW, the Jedi mind trick.
002R PT7.3.1 MacBook Pro 2.33 OS 10.4.8 |
How to REMOVE instrumental from a track? | YichenWang | Tips & Tricks | 6 | 02-26-2012 09:49 AM |
Instrumental Rock Track 11R | PMcC | Eleven Rack | 13 | 02-04-2011 10:42 AM |
Mixing and mastering | Thegenni | Tips & Tricks | 13 | 04-25-2010 12:31 PM |
Creating Space In Instrumental/ Vocals Sit On Instrumental | walkerd96 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 10-25-2009 12:13 AM |
MASTERING AND MIXING | Johnny Cadelco | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 07-04-2007 02:46 PM |
