Old 11-15-2004, 12:43 PM
TheBaron TheBaron is offline
Default Rookie routing question
I want to run a clean guitar line into the Digi 002R to record while, at the same time, route that same guitar signal out through a Pod and back into a separate input to record the distorted signal, as well. How do I do that? It seams simple but I've been scouring the manuals and experimenting and I haven't been able to get a signal to the pod and back. I'm embarassed that I even have to ask for help but my attempts so far have been foiled.
Old 11-15-2004, 01:59 PM
Ben Jenssen's Avatar
Ben Jenssen Ben Jenssen is online now
Default Re: Rookie routing question
You could do it like this:
Run the signal into track 1,
create a send on that track wich goes out on output 3 f.ex,
plug the pod into output 3,
send the output of the pod to a new recording track.
There will be some latency.
You could of course record the clean signal first, and send it out to the pod later.
Old 11-15-2004, 02:36 PM
Do I want to assign the output as a bus, or simply assign it to a different output. Do I have to create a submix channel to bring it back? If so, there's no record option on a submix so how do I send that to a recordable channel? I'm pretty sure that I tried your suggestion but I wasn't able to get a signal back in. Are there any tricks to the I/O hardware setup?
Old 11-16-2004, 05:34 AM
JFreak's Avatar
JFreak JFreak is offline
or you could just use a DI box
Janne
Old 11-16-2004, 11:40 PM
Radial makes a box designed to split a guitar signal and send to 6 or 7 amps without loading the pickups. Or trade up to a POD Pro which has a clean output on the back just for that purpose.
Another rookie question ??? RHDRAMA Pro Tools SE and Essential (Mac) 1 01-11-2011 10:24 AM
Rookie Question nexty76 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 01-31-2010 10:17 PM
rookie recording question... deejfro 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 10-06-2005 11:45 AM
Help! rookie question, but pls help! dkrz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 04-04-2003 01:02 AM
really rookie question 18Duffs 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 07-11-2002 05:33 PM
