UAD livetrack error in PT 2018.1
Brand new to UAD, just got at Quad Satellite USB for use in Win 10 PT 2018.1. All the plugins cause the following error if I try to engage livetrack:
One or more UAD plug-ins have been disabled. Device code -50 Is this a known thing? I know Firewire Satellites don't work with Livetrack, but it says USB 3 should.
Guy Rowland www.guyrowland.co.uk www.sound-on-screen.com - Original audio clips of movies, TV shows and games, licensed as regular production music. PT 2024 Ultimate; W11 Pro; Ryzen 9 7900; 64gb RAM; RME Babyface; UAD Quad Satellite USB; GTX 1050i Macbook Air M2; 24gb RAM |
Re: UAD livetrack error in PT 2018.1
I see you have PT12 and 10 as well. Does it do it with those as well?
Let's try to isolate the issue if possible. |
Time for me to update my sig! I honestly haven’t used PT 10 for well over a year, it doesn’t really work on current Windows any more.
But perhaps more significantly, I get identical behaviour with an identical error code in Cubase 9.0.30. I’m on the latest version of UAD plugs and firmware up to date.
Thanks Drew - looks like a pretty tedious drag. I guess it has to be a system-wide UAD issue though eh, and if it's not shared by others must be something up with the install.
yeah, sad to say. That's why I asked you to check another app before recommending this.
Thanks Drew. OK, I followed the instructions as far as I was able, but having uninstalled I had no device driver as described in Device Manager, so there was nothing to uninstall there. I've reinstalled and rebooted, but no change in behaviour, sadly.
And it does it even with just one track and one plugin?
Livetrack stresses the CPU a good bit. |
Weeellll.... I just checked. I started with a Helios EQ in Cubase which has one of the lowest reported DSP usage. It went into livetrack fine. Then I worked my way up to Ocean Way Studios. Also fine. Then I went into PT - all fine there too.
So.... um.... now it's all fine! I can only presume that the system needed another restart after the reinstall. Most odd though, because I don't remember touching anything after that restart, and the install was essentially complete. Looks like it was One Of Those Things. Happy days from here hopefully, thanks for your help Drew.
Nice!!
Keep us posted. |
ProTools 2018.1 | PTPerson | ICON & C|24 | 4 | 02-19-2018 01:08 PM |
PT 2018.1 and Yosemite ? | wwittman | Pro Tools 2018 | 6 | 02-12-2018 05:38 PM |
Pro Tools 2018.1 (12.9) | thanos4 | Pro Tools 2018 | 160 | 02-05-2018 07:41 AM |
Freezing all outputs of a multichannel instrument track causes -9400 error 2018.1 | noiseboyuk | Pro Tools 2018 | 7 | 01-29-2018 12:48 AM |
