PT12.6HD -9171 errors
Keep getting these 9171 errors. Ideas where to start? OS 10.11.6 Sent from my iPad using Tapatalk |
Re: PT12.6HD -9171 errors
Open a case with Avid. They told me that changes were made to reduce the occurrences of these errors in v12.6.
...i did a case , regarding 9171 , the suggestion was to use higher buffersizes
( in my case above 512 ) , which is not very helpfull when you want to record with plugins....... btw im on HDX , CPU at appr. 2% , nearly only DSP plugins and get this 9171 often in the first attempt in playing back a session , regardless if 100 or 1 track.
foley artist , soundeditor |
Is this happening with multiple VI's open?
Best Mitch MacPro 2.44 8 Core Mac OSX 10.10.5 PT 12.7 HD Native SyncHD I/O HD I/O MIDI I/O C24 Aja LiHi Surround Setup |
Exactly same thing here Sent from my iPhone using Tapatalk
Ok - I'll try to open a case with Avid.
In the meantime... My buffer size is already 1024. I'm getting 9093 error also - probably same family. |
Have you sent both your .ptx session file and .dlog file to Avid for analysis? Do you have any plug-ins instantiated in the sessions where you are receiving these -9171 errors? If so, ask Avid if they can identify which plug-in is implicated in the -9171 error. You may want to then follow up with that plug-in developer and see what they have to say about the error.
Do you have any other applications active when these -9171 errors occur? If so, try to quit as many apps as possible and see if it helps in any way. As I understand it, these errors are related to audio not getting somewhere within the Pro Tools mixer within a specified period of time. The larger your buffer, the longer you can go until time's up and the error appears. Enabling Ignore Errors During Playback/Record may also help, though I do understand that clicks and pops you may hear are unacceptable for other reasons.
No, haven't sent the ptx file yet. I will save a copy of the session file next time the error shows.
How to I get the dlog file? I will note which apps are open also when it happens. Hope Avid responds soon. Thanks. |
Thanks
-9171 and -9172 errors with Pro Tools HD 10.3 on HDX | Boe Larsen | Pro Tools HDX & HD Native Systems (Mac) | 519 | 03-08-2017 10:11 PM |
I solved my 9171 errors | fifty8th1 | Pro Tools 12 | 5 | 05-17-2016 04:17 PM |
Anyone having -9171/-9172 errors on 12? | rinky | Pro Tools 12 | 2 | 03-25-2015 10:32 AM |
64 Sample Buffer and -9171 Errors | sws2h | Pro Tools 10 | 2 | 07-19-2013 07:21 PM |
Dae errors -9171 after installing 10.3.3 | TCM | Pro Tools HDX & HD Native Systems (Win) | 3 | 02-06-2013 10:18 AM |
