Import mix settings
Hello
I am mixing some songs and have finished the first one. Now I want to import my channel settings and plugins and stuff into the next session and start there since I more or less want the same sound in that song. I know in HD that is real easy to do but it seems that in LE that functionality is very limited. I was just wondering if anyone has some good tips and tricks on how to work around this limitation in LE. An easy procedure or something. I don't want to waste time assigning the same plugings and settings for all sessions if there is an easier way. Thanks in advance Alex |
Re: Import mix settings
It would take a little extra time, but you couldn't you save a session copy of your first mix, open that copy and delete all the audio files and wipe the automation, and then use THAT session as your "mix template"?? Then all you do is inport session data of the next song, and so on, and so on.
JC Richardson C.A.S. Magick Lantern Atlanta |
Yeah that is true. That is a workable solution.
Thanks. |
Do not import I/O settings | ChrisMac | macOS | 10 | 11-12-2012 01:11 PM |
is it possible to import settings from one project to another? | TDub | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 07-13-2010 09:43 PM |
Import I/O settings problem? | PTGuy | Pro Tools TDM Systems (Mac) | 2 | 04-03-2006 12:24 PM |
Best way to import I/O settings? | Lawson | Pro Tools TDM Systems (Mac) | 6 | 04-09-2005 06:31 PM |
import plug in settings??? | smlworld | Pro Tools TDM Systems (Mac) | 2 | 08-23-2001 12:22 AM |
