Old 04-05-2019, 06:23 AM
yanos yanos is offline
Default Pro Tools Control does not work any more
Hello,
I run Pro Tools Control v18.3.0.208 on an old Ipad (Ipad2 IOS 8.4.1), on a MacPro 5.1 OSX Sierra 10.12.6, with Pro Tools Ultimate 2018.7 without issue since I used it.
Last day I work (the day before yesterday) there was no problem. But not today, without any reason I have changes nothing on my computer !!
Eucontrol is connected on the computer and Pro Tools Control show Pro Tools running (Pro Tools 18Mac is written in green on the app).
And I can see my personal Softkeys on the app, however it is the only connexion between both.
Connexions between PT Ultimate and PT Control are by wifi, Eucontrol version is 18.3.0.244.
I reinstall Eucontrol on my computer, Pro Tools Control application, restart my computer but without chance. It doesn't work.
What can I do ?
Thanks !!
MacPro 5.1 (2 x 3.46 GHz, Twelve Core Intel Xeon) - OS X 12.7.3 - Ram 64G - PT Ultimate 2024.3.1 - HD Native Card - Avid HD Omni - Monitoring PSI Audio (surround)
Old 04-06-2019, 08:19 AM
Default Re: Pro Tools Control does not work any more
Ok, I will soon test with an Ipad more recent. But I don't understand why it stop working overnight…
Old 04-06-2019, 09:34 AM
jeffro's Avatar
jeffro jeffro is offline
Are you able to update your iPad's OS? avid.force.com/pkb/articles/compatibility/Pro-Tools-Control-Support has some good troubleshooting info but also states...
Pro Tools | Control v2018.3 requires iOS 12
linkedin
Old 04-06-2019, 10:06 AM
No unfortunately I can't, this Ipad is too old. It would have surely resolved all this.
But what I really do not understand is that it worked, and suddenly it stops…!
Old 04-06-2019, 03:43 PM
EddieJones's Avatar
Can you check EUCON is enabled in Pro tools peripherals settings
Old 04-07-2019, 11:38 PM
Thanks a lot EddieJones it works !
I checked everythings, appart this box that was (not by me) unchecked and so EUCON wasn't enabled, shame on me .
I installed last PT Ultimate 2018 version (12.0) and it's ok with my old Ipad not qualified by Avid. Great !
EuControl v3.7.0/ Pro Tools | Control on iPad Pro doesn't work... Smithtrax Avid S1, S3, Dock and Control App 47 03-10-2018 07:48 PM
Mackie Universal control Pro only work with protools11 dose not work 10.3.9 why??? sayed mohammed Windows 6 11-11-2014 08:22 PM
Cannot get Graphite49 to work with Pro Tools 11 as a control surface sandwich MIDI 0 02-09-2014 11:23 AM
Need Pro control Dll or bundle to work with Pro tools LE 9 on PC hart07 ProControl, Control|24, Command|8 2 05-26-2012 03:41 PM
How does the Mbox Pro Control Panel Work with Pro Tools 9? Confused. blkdog7 macOS 2 02-03-2011 08:18 AM
