Old 02-08-2018, 03:15 PM
[email protected] mike.wax@scorpion.co is offline
Default Re: Jam Sync Pro Tools with Camera
Hey guys,
I got a BNC to XLR adapter from Amazon. I plugged it into my mixer into Ch 1 and hooked that up to my UltraSync. set everything up with LockStep according to the video (setup an IAC Bus, did the Peripherals in PT, etc.).
When I put PT online (clicked the little clock icon and the MTC button), It doesn't appear that PT is following my time code on my UltraSync. When I try to press record, nothing happens.
Did i miss something?
Thanks!
Old 02-08-2018, 03:19 PM
Ryan Young's Avatar
Ryan Young Ryan Young is offline
Just to check, do you see the Ltc feeding lockstep? And does it say what framerate it’s getting? If so, go to pro Tools session setup window and make sure your session is set to the matching framrate.
Originally Posted by [email protected] View Post
Hey guys,
Thanks!
-Ryan Young
•2019 Mac Pro 3.5 GHz 8-Core Intel Xeon W - 48 GB 2666 MHz DDR4 (OS 10.15.5) •HD Native PCIe, HD Omni, 192 I/o, Pro Tools Ultimate •Avid S3 + Dock •Blackmagic Intensity Pro (HDMI) •5.1 Room with JBL LSR4300 series
Additional Systems
•2010 Mac Pro 2 x 2.66 GHz 6-Core Intel Xeon - 48 GB 1333 MHz DDR3 (OS 10.14.6) •HD Native PCIe, 192 I/o, 96 I/o, Pro Tools Ultimate •McMix (x4), McControl (x1), JLCooper Surround panner for D-Command ES, Avid Control •Blackmagic Intensity Pro (HDMI) •7.1.4 Room with JBL LSR4300 series
•2017 MacBook Pro 2.8 GHz i7 - 16 GB 2133 MHz LPDDR3 (OS 10.14.6) •HD Native TB, HD Omni, Pro Tools Ultimate •McMix (x1), McControl (x1), Avid Control * or * D-Command ES Main Unit •Fed into whichever system is the main system
Old 02-08-2018, 03:23 PM
The FPS on my jam syncer is set to the same as PT (23.98). I'm not sure if LockStep is getting the feed. It just says "Online - waiting" so i think no...? LOL but not sure what else to check.
Maybe I need to adjust something on the UltraSync?
Old 02-09-2018, 11:26 AM
I got LockStep to receive the incoming timecode (attached image). it says the TC and the FPS. I have matched my Pro Tools session with the same FPS in the Session settings.
I have Pro Tools online, but I am still not able to record in Pro Tools. I have my audio tracks record enabled, but PT does nothing.
Old 02-09-2018, 11:42 AM
Got it!!!
The audible timecode needs to be turned up so LockStep can "hear" the signal.
Thanks for all the help guys!!!!!!
HTML code is On
SMPTE Time code in Pro Tools (multi camera live feed + audio sync question) Bergsten macOS 9 04-01-2019 03:31 PM
Sync Audio - Editor Used Camera Track Only -Waveform Sync? milosziv Post - Surround - Video 7 11-30-2011 05:26 AM
How do I sync PT8 LE with my DV Camera? luts Post - Surround - Video 3 06-27-2010 12:31 PM
Sync camera's to a pair or 192's BookSix Pro Tools TDM Systems (Mac) 7 10-20-2009 09:47 PM
Super 16mm crystal sync camera on location w/ Pro Tools! sorinnitoi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 05-29-2007 07:57 PM
