Freezing all outputs of a multichannel instrument track causes -9400 error 2018.1
Wow, I'm having a bug catching morning. Anyone else got this? Tested here in W10, using Omnisphere and Kontakt.
1. Create a mulichannel instrument (with at least 1 aux attached). 2. Freeze All (including all attached auxes) 3. Playback = AAE error -9400 or -9405 (I get the former with Omnisphere, the latter with Kontakt). Also weird - when freezing the entirity of a 2nd instance of Kontakt, it also froze a different instance. Also also weird - freezing just one aux works fine. Freezing 2 out of 8 in Omni works fine. Freezing 3 or more causes the playback error. On a 2 output instance of Kontakt, freezing 1 was fine, freezing both causes the error. EDIT - this is working normally for me on the Mac, just a PC issue.
Guy Rowland www.guyrowland.co.uk www.sound-on-screen.com - Original audio clips of movies, TV shows and games, licensed as regular production music. PT 2024 Ultimate; W11 Pro; Ryzen 9 7900; 64gb RAM; RME Babyface; UAD Quad Satellite USB; GTX 1050i Macbook Air M2; 24gb RAM Last edited by noiseboyuk; 01-28-2018 at 11:49 AM. |
Re: Freezing all outputs of a multichannel instrument track causes -9400 error 2018.1
would be good to know some more info .. what versions of Omni and KOntakt for one thing ?? also, is PTHD10 still installed on both your Machines .. ( i saw in your other post where you are getting the Asertion error that you tested on both Win10 and HS) is HS the newest 10.13.3 or ??
Hi John - Omni and Kontakt are both up to date latest versions. PT10HD is installed on Win 10 but not MacOS. MacOS is 10.13.2 - I haven't checked this one on the mac yet, will be able to do that tomorrow.
Guy Rowland www.guyrowland.co.uk www.sound-on-screen.com - Original audio clips of movies, TV shows and games, licensed as regular production music. PT 2024 Ultimate; W11 Pro; Ryzen 9 7900; 64gb RAM; RME Babyface; UAD Quad Satellite USB; GTX 1050i Macbook Air M2; 24gb RAM |
so you got the latest OMNI from a few days ago .. and i am still using the older K5.5.2 .. i have the other installers but just can't update due to others i work with still using K5.5.2 ..
...actually just checked this on the mac now, and it's behaving normally so looks like this one is PC specific for me. Will update the OP.
PC peeps where are you !!!!!
Mac only guy here, but I know for certain that PT10 was never supported with W10.
...just to be clear, I'm not currently using PT10 at all, I haven't needed to do that for nearly a year, but it is still installed as a just-in-case. I'm curious, is there a suggestion that this error might be caused by PT10 being present on the machine?
Deleting multiple instances of multichannel instrument presets causes crash in 2018.1 | noiseboyuk | Pro Tools 2018 | 4 | 01-29-2018 06:43 AM |
Assigning Kontakt outputs to Instrument track in PT | sky88dd | Virtual Instruments | 0 | 09-27-2007 03:34 PM |
midi outputs? aux track or instrument track? | pikapikapi | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 12-19-2006 02:28 AM |
I/O Presets for Multichannel Outputs | Dawarrior | Pro Tools TDM Systems (Mac) | 1 | 07-21-2006 05:41 PM |
RTAS v7 and multichannel outputs | Dan Pinder | Pro Tools TDM Systems (Mac) | 2 | 11-07-2005 06:19 PM |
