Old 04-04-2016, 02:05 PM
gavriil1 gavriil1 is offline
Default What has screwed up my busses? I/O
Guys, I need your help. I dont know what I did but I keep getting these messages in the attachments I am showing below. These songs were made with the same DAW, same version. I dont know what I changed for me to be getting these but all my ducking has been screwed up etc. Is there anything I should do in the I/O section in order to fix this? Thank you.
PT 11 with APollo Quad on PC.
Old 04-04-2016, 02:15 PM
mesaone mesaone is offline
Default Re: What has screwed up my busses? I/O
See if everything works as expected when you un-tick the "map to output" boxes of Reverb, Delay, and Chorus. While you're in there, go to the Output tab and hit default. That should clear up the issue with the SPDIF and Phones buses.
Pro Tools HD 12.4, Pro Tools "Vanilla" 12.4, Artist Transport, 2x Artist Mix
Studio Blue: RME UCX, Win7 Pro, i7 960, 16GB || Studio Green: RME Babyface, Win10, i7 7700HQ, 16GB
Old 04-04-2016, 07:18 PM
zedhed's Avatar
zedhed zedhed is offline
Once you have it sorted, use the 'export' function to save I/O settings so that you can recall them at a later date should they be needed.
This is particularly handy for heavily customized I/O as it saves having to start from scratch renaming paths.
Too much blood in my drugstream
Motherboard: Gigabyte Z690 AERO D
CPU: Intel Alder Lake Core i9-12900K
CPU Cooler: Noctua NH-D15S
RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz)
Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples)
1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro)
GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4
PSU: Corsair HX Series HX850 Platinim
CASE: Fractal Define XL R2
PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII
HD 96I/O
Old 04-04-2016, 08:34 PM
YYR123's Avatar
YYR123 YYR123 is offline
That still works in 11? B/c it's broke in 12
Daniel
Old 04-04-2016, 08:51 PM
jjnssn jjnssn is offline
The export function is broke in 12? What is it doing wrong?
Old 04-04-2016, 08:54 PM
YYR123's Avatar
It errors out when you try to save the io setup
Daniel
Old 04-04-2016, 09:15 PM
Ok. I haven't seen that error yet however I have deep seeded issues with the I/O settings causing hangs during closing sessions and saving changes in 12.
HELP! Screwed Something Up stringsandkeys89 Tips & Tricks 11 03-13-2011 01:50 AM
5.1 mix busses screwed...enough to drive me insane mrtunes Pro Tools TDM Systems (Mac) 6 08-12-2005 04:34 AM
I Screwed It Up hookiefree 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 07-02-2003 06:19 AM
did i get screwed? Jbrooklyn 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 11 03-06-2003 07:03 PM
Am I screwed??? Mr Peete 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-23-2000 03:54 PM
