Old 12-02-2013, 04:39 AM
Detlef Brockmann Detlef Brockmann is offline
Default Re: Keyboard access of menu commands broken in 11
Using Pro Tools 11.0.2 and OSX 10.8.5.
Shift+Apple+G works fine here but not the custom made shortcuts.
Come on Avid!!!
Detlef.
Old 12-02-2013, 06:36 AM
cuttothebeat cuttothebeat is offline
Sorry - I started a new thread on this before looking. Very bad of me. I RELY on these shortcuts. What's with not being able to customise the KB like in Media Composer, FCP, Premiere etc anyway! Please fix
Old 12-02-2013, 06:40 AM
bleen bleen is offline
Come on Avid!!!
Detlef.
Fascinating - Shift+Command+G has never worked since installing PT11 here. Edit window, Groups pane, Command focus in either, doesn't matter - hitting Shift+Command+G flashes the Pro Tools menu and nothing else happens.
PT Ultimate 2019.10
Avid S3
Mac Pro 6,1 (2.7GHz 12 Core, 32GB RAM, 512GB boot)
macOS 10.14.4
Lynx Aurora(n)/HDX/Sonnet Echo Express III-D
don gunn
Old 12-05-2013, 06:44 AM
OK so having worked for 2 days without my custom shortcuts I am finding work painfully slower than before. I am gutted that I parted with several £££s to make my system worse in terms of crashing and usability.
Although I can't rule out a problem with Mountain Lion and shortcuts, I did make one for another application and it worked as usual. What would be the best way to get Avid to notice this problem?
Old 01-10-2014, 01:08 PM
since Pro Tools 11.1 and OSX 10.9 the custom shortcuts came back to Pro Tools.
  #16
Old 01-10-2014, 04:09 PM
I have them working again on PT11.1.1 after also updating my OS to 10.8.5.
PT Ultimate 2019.10
Avid S3
macOS 10.14.4
don gunn
  #17
Old 01-31-2014, 09:58 AM
dtonthept dtonthept is offline
Hey all,
I was experiencing the same problem, and found that in "services" in the system prefs, under keyboard, that Gobbler automatically creates a "send via Gobbler" keyboard shortcut using, yep you guessed it, shift+command+g. Un-ticking the box has restored Pro Tools to its expected grouping functionality.
Yay.
D
  #18
Old 04-11-2016, 06:20 AM
steins steins is offline
Originally Posted by strangepumpkin View Post
I found a solution to the custom shortcuts issue. This will work provided you've already setup some shortcuts in PT 10.
Open com.digidesign.ProTools.plist in User/Library/Prefences with an editor like TextWrangler
Copy the section marked "NSUserKeyEquivalents" from <key> to </dict>
Then open com.avid.ProTools.plist and paste that info between <key>NSNavPanelExpandedStateForSaveMode</key>
<true/> & </dict>
That should activate some of the shortcuts you had before. Unfortunately, you still won't be able to edit these shortcuts via System Preferences>Keyboard
But hopefully that helps you out.
It doesn't completely resolve the issue. You can't replace active PT 11 shortcuts with custom ones, but you can add shortcuts where there weren't any before.
Thank you, you made my day!
Stein Tore
Stein Tore Sønsteli
Pro Tools Ultimate 2023.12 (HDX-2), Mac Studio M1 Max, MTRX Studio, Avid I/O's, S1 + Dock
Alt-menu keyboard shortcuts - Alt+F for file menu, etc. scullionj Windows 7 11-22-2015 08:59 AM
Keyboard Commands in OSX Ozzie Pro Tools TDM Systems (Mac) 0 10-08-2006 06:18 AM
Key commands suddenly controlling Audiosuite menu? WannabeSQ 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 02-16-2006 02:36 PM
Keyboard commands Extreme Mixing Pro Tools TDM Systems (Mac) 3 07-13-2005 06:13 PM
keyboard commands for ? surchur 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 11-19-2001 07:12 PM
