Old 05-02-2013, 05:06 AM
PT user PT user is offline
Default confused about omni inputs!
Having read the manual and looked online Im a bit confused about in/outs on my new Omni.
Can someone please confirm how many simultaneous inputs it can run. Is it 4 or 8?
I have set mine up without the monitor functions (set to none as the manual suggests) as I have a dedicated monitor section in my studio. Can the internal software controlled mixer page function via the line outs instead of just the headphone outs in this config? Is there a better way to go about it?
Old 05-02-2013, 08:41 AM
nst7 nst7 is offline
Default Re: confused about omni inputs!
The max I/O is 8 in, 8 out. Any combination of analog and digital. So for the inputs, you could have 4 analog, 2 spidf, and 2 adat, or 2 analog, 6 adat, etc.
For the outputs, the same thing applies. Although you can have up to 8 analog. But you still could decide to have 6 analog, and 2 adat, or some other combination of outputs, etc.
On outputs, you also have the hardwired Cue outputs for the headphones, which shows up as output 9-10 in Protools, and is available when the "Cue" button is pressed for the headphones.
As for the mixer function, it requires some kind of monitor path to be set up. It will not work if you don't have a monitor path of some kind set up.
Old 05-02-2013, 10:09 AM
Cliffy_Boy's Avatar
Cliffy_Boy Cliffy_Boy is offline
Keep in mind there are only 4 analog inputs and 2 of them may be preamps
Old 05-03-2013, 01:28 AM
P,B,S P,B,S is offline
The omni also only allows 10 outputs. 2 for headphones plus 8 more.
If using as a monitor controller the monitor outs do count against that so now you only have six outputs.
BUT
Monitor outputs can be mirrored giving you the 8 plus 2 , but they will be the same outs as the outputs sent to the monitors.
Also the sends on the insert are always active. but of coarse you need to be using the OMNI pre,s for that to happen.
Old 05-03-2013, 09:43 AM
I'm not aware of any mirroring function on the Omni.
Old 05-03-2013, 10:24 AM
dwaynedelario dwaynedelario is offline
The TRS outputs, afaik, will mirror outputs 1/2 or 7/8 as you choose in the hardware setup page.
Old 05-03-2013, 12:05 PM
Thank you for everyones " input" .excuse the pun :)
Interesting point about the optical outs. I measured the calibrated analogue out so -20bdfs = PPM4 for Post work. However if I make the optical outs the monitor out they drop to PPM2.5. That cant be right. If it is its not pro.... This equates to Control room (CR) out going from 0 to +6 in order to match....
Old 05-09-2014, 01:36 PM
mandal mandal is offline
I tried the combination of AES/EBU and Optical (Toslink)
...but didn't succeed.
The Optical (Toslink) is ADAT Optical using sample rate of 44.1 kHz
To use the Optical I needed to select "Optical (S/PDIF)" in the Hardware Setup.
Is it not possible to combine AES/EBU and Optical (Toslink) ??
Please advice...
Microsoft Windows 11 Home 64-bit OEM DVD
Avid OMNI PCIe
Pro Tools Ultimate 2023.12
CPU: Intel Core i9-10980XE
Motherboard: Gigabyte X299X AORUS MASTER E-ATX
RAM: 64 GB Crucial Ballistix Sport LT DDR4
Screen card: MSI GeForce GTX 1660 VENTUS XS OC
Old 05-09-2014, 02:42 PM
feliponk's Avatar
feliponk feliponk is offline
8 outputs at any given time.
Felipe Gonzalez A.
Avid ACSR Elite
Dante Certified
http://felipousismix.wix.com/felipousismix
Open Core Mac Pro OSX Ventura | ProTools HD 2023.x | Merging HAPI ADA8 | UAD Quad PCIe | Kali IN-8 | Presonus Temblor 10 | Softube, SSL, Universal Audio, Slate Digital, McDSP, Fabfilter, Plugin Alliance among other plugins
Old 05-09-2014, 10:41 PM
output ?
Avid OMNI PCIe
...add more inputs to OMNI mandal Pro Tools HDX & HD Native Systems (Win) 28 03-20-2017 09:51 AM
HD Omni inputs vin7 Pro Tools HDX & HD Native Systems (Win) 4 03-04-2013 08:36 PM
HD OMNi + 8 pre Adat how many inputs? Claudioska Pro Tools HDX & HD Native Systems (Mac) 6 02-18-2013 08:12 AM
I'm kind of Confused on inputs! acq1 Pro Tools M-Powered (Win) 2 01-19-2009 09:52 AM
Confused about MIDI inputs and outputs JDnSTL 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 11-18-2003 08:35 PM
