Old 03-21-2009, 01:12 PM
MajorLeagueEntertainment MajorLeagueEntertainment is offline
Default iLok 64 bit error(anyone know the link)
ive been searching on something about the iLok not detecting the software installation when you try to sync on the website, but i can not find any topic on this forum about it...
does anyone have any ideas if one does exist i know someone mentioned it but i just cant get my hands on it?
Sager Notebook (9262)
Windows Vista Ultimate (64 Bit)
4 GB DDR2 SDRAM
Intel Q6600 Core 2 Quad @ 2.4 Ghz
320 GB SATA 300 @ 7200 RPM w/ Raid 0 Stripe
Nvidia GeForce 8800M GTX
Roland Fantom X6
Mbox 02
Pro Tools LE 8.0
Fruity Loops 7 XXL Aired Edition
Old 03-21-2009, 02:14 PM
JMS40 JMS40 is offline
Default Re: iLok 64 bit error(anyone know the link)
I may have steered you wrong in your other thread. It may have been a workaround for Win7 I was remembering.
There have been quite a few 64 bit threads, though.
Old 03-21-2009, 06:58 PM
sw rec sw rec is online now
VERY well documented on here that PT is NOT qualified to run on a 64-bit o.s. so the first thing to do is what's recommended and stick with a 32-bit o.s.
Old 03-21-2009, 11:42 PM
its not recommended but it sure as hell works 100% fine...
sorry for the language but it seems to me some people don't want it to work in a 64 bit enviroment...
as I said PRO TOOLS is working 100% the only error is ILOK!!! which is not made by digidesign...
how about you stick with your 32bit systems while i reap the benefits of increased memory...
4 GB DDR2 SDRAM
Roland Fantom X6
Mbox 02
Pro Tools LE 8.0
Old 03-22-2009, 12:30 AM
sunburst79 sunburst79 is offline
Did you go to PACE and download the 64bit interlok drivers? That would be step number 1. The only workaround that I'm aware of with the 64bit Pace and iLok drivers was needed with Windows 7. As I recall the Pace drivers installed just fine in Vista64. Check iLok for 64bit drivers as they will need to be downloaded also.
You shouldn't have a Pace or iLok problem with Vista 64.
Scott
Formerly Hobo Wan Kenobi
Core 2 Specs Page
ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88
Old 03-22-2009, 11:10 AM
Yeah, it's strange I did everything(I'm pretty tech savvy). I contacted support and they told me that there is a known error with 64 bit installations and they are currently checking out my setup log to see if they can spot anything.
Am I the only one using Pro Tools in Vista 64 bit?
Sincerely I'm scared of upgrading to Windows 7, vista 64 bit took a long time to clear out all the bugs and I can only imagine compatibility nightmares with 7(unless it's all based on the vista 64 technology)...
4 GB DDR2 SDRAM
Roland Fantom X6
Mbox 02
Pro Tools LE 8.0
Old 03-22-2009, 11:27 AM
Whats the exact error message? I assume you have downloaded the pace and iLok drivers?
There are a few folks running Vista 64-not many as it only working with USB interfaces. Win7 is pretty much up and running just the same as Vista at this point.
Scott
Core 2 Specs Page
Old 03-22-2009, 11:45 AM
on firefox it says the active X control for the device is not responding, and then tells me i should update it to the new version...
I have tried installing and reinstalling the new client installer and driver and still same messages.
In IE7 it tells me the client is not installed on my computer.
Im trying right now to install the 32 bit client maybe it can run on compatibility mode... hopefully *edit (did not work)
4 GB DDR2 SDRAM
Roland Fantom X6
Mbox 02
Pro Tools LE 8.0
Old 03-22-2009, 11:46 AM
just out of curiosity, do you think win7 is better than Vista64?
4 GB DDR2 SDRAM
Roland Fantom X6
Mbox 02
Pro Tools LE 8.0
Old 03-22-2009, 11:57 AM
I think the potential is there for improvement over Vista but as long as its using the same driver as Vista the performance will be about the the same. Win7 itself is rather nice. Digi will need to rewrite the driver after it it ships.
Scott
Core 2 Specs Page
Satellite Link & Video Satellite Link error on Pro Tools 9 HD 9.0.3 billegates macOS 0 09-24-2013 02:28 PM
Direct Link for iLok Support Ticket submission HERE. Drew Mazurek Pro Tools 11 1 06-22-2013 12:14 PM
Help! Ilok run time error while moving license to another ilok. poem Pro Tools 9 5 11-27-2011 06:30 PM
error: missing ilok authorization for pro tools 9. please insert the necessary ilok.. weakluv Windows 2 07-07-2011 05:47 PM
iLok.com Client Software download link broken? soundthinker Pro Tools TDM Systems (Mac) 2 11-19-2004 07:55 AM
