DAE can\'t get audio from the drive(s) fast enough.
Hello there.
I am looking for help with the following problem: DAE can't get audio from the drive(s) fast enough. Your drive may be too slow or fragmented, or a firewire drive could be having trouble due to the extra firewire bandwidth or CPU load. (-9073) I have recently purchased the M-Audio Firewire 1814, and Pro Tools M-Powered. I am trying to open and work with some tracks I recorded in a professional studio 2 years ago. When I open a track file I get the following messages: 1-'This session was saved with the following playback engine: Pro Tools HD 2 DSP, 48 Voices'. This playback engines is not available with the current hardware. Would you like to continue and use the current playback engine: Firewire 1814?. After pressing ok I get the following message: 2-'The original disk allocation for this session cannot be used. Check the disk allocation window to see what's changed. Your I/O setup has changed since the last time this session was saved. Check the I/O setups window to see whats changed. Some inputs were made inactive. Would you like to save a detailed report? I press Yes and the track loads. Now here is the issue. When I hit play I get the following message: DAE can't get audio from the drive(s) fast enough. Your drive may be too slow or fragmented, or a firewire drive could be having trouble due to the extra firewire bandwidth or CPU load. (-9073) My track files are on an external USB Hard Drive, and my G4 has the following characteristics: Processor 1GHz PowerPC G4 1MB L3 Cache 1 GB DDr SDRAM Can anyone please help me? thanks in advance |
Re: DAE can\'t get audio from the drive(s) fast enough.
Try a firewire hard drive. Not sure about that, but I think PTMP can't handle 48 voices. Hope this helps.
iMac C2D 2.4GHz, 4GB RAM, 10.6.3, 003R, PTLE 8.0.4, Logic Express 8.0.2 |
A USB drive is definitely too slow for this - as suggested, you need a firewire drive.
Thanks a lot guys!
MOVED ALL MY FILES OVER TO A FIREWIRE DRIVE AND PRESTO! IT WORKED... |
DAE Can't get audio from the drive(s) fast enough | zames | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 03-04-2011 10:47 AM |
"DAE can't get audio from drive fast enough. Drive may be too slow or fragmented, or | iminzayne | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 16 | 04-15-2010 10:28 PM |
DAE Can't get audio from the drive(s) fast enough? | daleh | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 42 | 09-25-2009 12:56 AM |
DAE can't get audio from the drive(s) fast enough. | Joemamma | Pro Tools M-Powered (Win) | 2 | 01-23-2007 07:16 AM |
DAE can't get audio from the drive(s) fast enough | tdellaringa | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 05-07-2006 06:07 PM |
