Audio track recording via midi triggering
Using DFHS for drum tracks triggered via midi controller, recording the midi track is successful, the triggering of the DFHS is successful as I hear them and they look as though they are routed to the correct tracks, as the tracks are recieving signal, but as soon as I try to record and depress record on the transport and the track, the LED indicator on that audio track goes down to zero and no signal is recorded (except the midi track). I'm sure this is a PT 101 question, but any help is greatly appreciated. Thanks, Michael |
Re: Audio track recording via midi triggering
Sounds like you are erasing the MIDI info at the same time you are recording audio so nothing is being recorded. Take the MIDI track out of rec mode so it does'nt record over the data that you had recorded. Make sure to press command z so you can get the data MIDI back.
Hope this helps, RS |
Resolved: Audio track recording vi midi triggering
Thank you for your response. I have resolved it. I was trying to record to the tracks were the drum samples were steaming to. Once I bounced the drum tracks to wav files, and imported them into audio tracks in PT, I'm cooking with gas now.
Thanks again. Michael |
Re: Resolved: Audio track recording vi midi triggering
Cool, Try using an Auxillary track (Stereo) with the drum module instead of an audio track then set the ouput to bus 1,2 (or whatever is available) then open a stereo audio track and set the input to bus 1,2. Put the audio track in record ready mode and record straight to the track. It should be easier then importing from a bounce file.
Good Luck, RS |
Triggering external sound module via MIDI track | Space Firebird | Windows | 3 | 04-17-2013 08:07 AM |
recording midi to audio track | godzflava71 | Pro Tools M-Powered (Win) | 3 | 07-27-2009 07:04 AM |
Midi Regions triggering wrong track | SteveWitt | Virtual Instruments | 2 | 01-20-2009 11:07 AM |
Recording Audio from Midi Track | Cucaracha | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 12-04-2006 01:10 PM |
Mbox2 Midi issue - Recording but not triggering | jpaz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 09-07-2006 01:47 PM |
