old setup on XP
Hello everybody, here is my problem:
Did a little song when I was running 5.0.1 on ME. It is not complicated at all, 4 guitar track and 3 vocal, each track have 2 plugins, EQ and D-verb. It was playing fine in ME, never had any problem ( I have a P3 1gighz and 384 meg of ram ). I backed it up when I received the new 5.3.1 because I upgraded to XP. Since then, I did much more complicated song ( 16 tracks with some [img]images/icons/cool.gif[/img] tracks having 3-4 plugins, verb, EQ, comp ). Never had issue with it. Now when I bring back the old song ( I had backed up the directory on a CD ), It will play for 45 sec, and then it is telling me that it ran out of CPU. When I watched the system usage, CPU is a little bit yellow, all the rest is totaly green. What is wrong??? Is it the way I backed it up?? It make no sense to me since I am doing much more intensive stuff since I upgraded to XP and 5.3.1. Thanx for any advice, info!!!! Metal PAT |
Re: old setup on XP
Hi Pat-
I think the session files must be 5.1 to be compatable with 5.3.1. Hopefully someone will correct me if I'm wrong. |
Re: old setup on XP
I am sorry, I made a mistake, it is indeed 5.1 setup that I am brigning over 5.3.1
Sorry PAT [img]images/icons/rolleyes.gif[/img] |
Re: old setup on XP
Don't forget to set the cpu-usage to 85%...
What's that? - That's the machine that goes "pling". Bastiaan |
Re: old setup on XP
Did you make sure to uncheck the Read only attribute on all of your files? I think that read only files will open in sessions but probably give problems when you're trying to get playback.
Mike Blanchard Engineer |
MIDI SETUP takes long to SETUP and doesnt SETUP | DartagnanSosa87 | MIDI | 3 | 01-28-2013 12:02 PM |
I/0 setup weirdness, sessions overwrite my setup | digidesigner | Pro Tools TDM Systems (Win) | 0 | 10-20-2011 11:40 AM |
PT 9 setup problem..Where are the MIDI IN options in setup menu?? | Blickerding | Windows | 0 | 04-06-2011 02:44 PM |
"Edit MIDI Setup" Setup Menu Item is Missing! | altemir | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 09-08-2004 12:24 PM |
OMS Setup: Interface Req'd? Setup referrences? | eltornado | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 11-19-2000 04:17 PM |
