Old 12-14-2011, 01:28 PM
springvalley springvalley is offline
Default PT 10 Low Latency Monitor using 828mk3
I am running PT10 on osx 10.7.2 Using a MOTU 828mk3 I am un able to get a signal to pass using analog 1+2 as an output the Low Latency option is lit and checked in the options menu. When enabling the track the plug ins and inserts go dim and you can see the signal on the meter. BUT you can not hear the signal until you play it back? Everything works fine with direct monitor when I use my digi oo2 console. Low latency direct monitor on 1 and 2.analog.. Does anyone know why the motu does not pass input signal in low latency mode? thanks
828mk3? stainless Pro Tools 9 0 11-25-2010 09:47 AM
compensating for monitor latency underbiteman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 03-25-2004 01:34 PM
Monitor latency in PT LE storm-01 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 02-27-2003 06:34 PM
Monitor Latency and monitor thru headphones output... jeronimo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 04-06-2001 08:30 PM
Monitor LATENCY. lukemaniak 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 01-30-2001 08:37 AM
