Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools M-Powered (Mac)
Old 03-26-2009, 03:39 AM
Lizardpoint Lizardpoint is offline
Default Macbook with MOTU 828Mk3
Hi team,
I'm looking to reduce the weight and amount of gear I use when recording away from the studio and was wondering if this is feasible ?
I currently use a Fostex 2424LV with 3 focusrite Octopres connected to a Roland line mixer. This lot fits into 2 stupidly heavy 6U racks.
Can I reasonably expect a Macbook (2Ghz white one) to record 24 tracks of audio simultaneously (at 44.1 or 48K 24 bit) ?
I already have the laptop so I could fund the MOTU purchase with the sale of the D2424LV.
Then I can connect the three Octopre's to the MOTU 1 via line inputs and the other 2 via lightpipe.
As the MOTU will allow me to mix onscreen, I can carry the Macbook and everything else in a 4U rack.
If I have to upgrade the Macbook to a Macbook Pro it may not be worth it.
What do you think ?
Is it Do-able ?
Cheers
Lizardpoint
Old 03-26-2009, 06:00 AM
Default Re: Macbook with MOTU 828Mk3 or Profire Lightbridge
I've just seen the lightbridge and this looks like a cheaper option.
I just need to know if anyone else has done it.
I'm also reading stuff about input channel limits on PTLE and M powered.
Can I record from 24 sources at the same time ?
Cheers
Lizardpoint
Old 03-28-2009, 03:21 PM
dvrooman dvrooman is offline
I don't have definitive answers to your questions, but I can point out a couple things. You can't use Pro Tools with the MOTU interface, so if Pro Tools a factor, you can immediately rule out the MOTU interface. Secondly, I can guarantee that you won't be able to simultaneously record 24 tracks on the Macbook's internal hard drive. It might be possible using a firewire drive, but I've never tested that quantity of tracks.
MOTU 828mk3 and Pro Tool 9 fiddlecat Windows 10 02-23-2012 07:43 PM
PT9 & Motu 828mk3 interface FT13 macOS 0 12-23-2011 09:37 AM
Chase SMPTE (LTC) with Motu 2408mk 3 or 828mk3 marspe Pro Tools 9 14 12-13-2011 06:09 AM
SMPTE connections options on the Motu 828mk3 chrisdee General Discussion 2 04-30-2011 01:08 AM
Any advice on best way to use 003 and MOTU 828mk3? hwalker 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 06-27-2009 09:13 PM
