Does AAX less CPU usage than RTAS?
Hi I just wonder if we load the same plug in efx, will AAX use less CPU , or have a better CPU cores managment than RTAS?
Thanks!
Mac Pro 3.0G 8 Cores PT HD use with Ensemble Thunderbolt |
Re: Does AAX less CPU usage than RTAS?
In theory the AAX plugins should use resources more efficiently because they are 64Bit
It's been a while but I do think there was a small bump in efficiency, but it wasn't huge. Keep in mind that devs could "clean up" the code during the process of porting, so in some instances, it's possible that the plugin format had nothing to do with any subtle increase. |
Since AAX and RTAS are simply an interface into the plugin, I doubt there is much difference in performance. The difference is not obvious to me, but many have said AAX is more flexible and efficient. There may be some differences under the covers for side chains, grouping, etc., but I haven't been using those features so I can't say for sure.
According to what I have gleaned from developer comments, Avid placed a high priority on security/copy protection, and also the ability to link AAX plugins to its store. |
Every plug-in is a tiny application which is a lot more than just a GUI. AAX is potentially more efficient but lacks the stability that a decade and a half of bug fixes gives RTAS. 64 bit AAX gave my seven year old computer a new life.
Bob's room 615 562-4346 Interview Artists are the gatekeepers of truth! - Paul Robeson |
I"ve found it to be a big bump in performance.
I have yet to hit the performance limit with plug ins in PT12
William Wittman Producer/Engineer (Cyndi Lauper, Joan Osborne, The Fixx, The Outfield, Hooters...Kinky Boots!) |
I think the more important feature Avid was aiming at was the transparent migration between a project done on AAX Native or AAX DSP. Unfortunately, not many companies bought into the DSP thing yet.
Dave Cournoyer-guitarist-project studio Mac Mini late 2012, i7, Sierra 16GB PT10.3.10HD PT12.5.2 Apogee Mini-Me firewire. |
64-bit AAX in PT 11 + 12 is a noticeable improvement.
32-bit AAX on PT 10 is in many ways a step back from RTAS. Memory-intensive VIs in 32-bit AAX have a habit of freezing the whole computer as soon as PT's memory usage is >2gb. often leading to the system becoming completely unresponsive and necessitating a reset. sometimes this happens even when the plugins are not being used in the session. |
CPU (RTAS Usage) | Newpostguy | Post - Surround - Video | 1 | 04-20-2010 03:53 PM |
CPU RTAS is =22% usage in PT8 from the Start | akhafaji | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 06-21-2009 10:15 AM |
RTAS CPU usage | studiogorilla | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 02-26-2009 09:57 AM |
CPU usage and RTAS | guppy pup | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 02-04-2007 04:58 PM |
DSP usage between RTAS & wrapped VST? | gerax | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 07-05-2004 05:40 AM |
