#21
Re: Bounce to disk sounds different from master channel
That's good practice if you a doing a fade, so you don't hit the compressor less as the music fades down, but it has nothing to do with what you are hearing and what goes to 'tape' - it's the same thing, always post fader!
Protools Studio 24.3, 2018 Mac Mini, Core I5 6 core, 16Gb ram, Sonoma 14.4, Focusrite Clarett+ 8pre, Focusrite Octopre. |
#22
They are pushing the digital mix window into saturation to get "the sound of the console" for the final mix ;^)
#23
Yeah I see your point- it has to be something with the OP's automation - b/c honestly it shouldn't sound different at all...
#24
Automation will be heard live in the session, same as the bounce...
#25
Should be......but it has to be explained by something doesn't it ?
#26
I reckon it's either 'bounce source' or playing back the bounce from within the session. The OP still hasn't said how he's playing it back.
#27
Just some friendly advice.
The OP's issue is almost assuredly user error during bounce or playback. |
#28
On a slightly different tack, just to clarify. I always bounce to disk real time because I have an outboard analog mastering comp on the 2 Bus and I am assuming that it's processing would not be included in an offline bounce. Correct ?
System : Studio - Avid Carbon interface , PT Ultimate 2023.12 Mid 2020 (intel) iMac 27" Ventura 13.2 .1 Mobile - 2021 14 " MBP M1 Pro PT Ultimate 2024.3.0 --Sonoma 14.4 Enjoy the Journey.... Kev... |
#29
yes. Unless Avid can rewrite the laws of physics that is...
#30
The only difference I've ever noticed with Offline Bouncing, is that on those weird, inexplicable occasions where Pro Tools decides to loose it's grip on MIDI timing (the metronome develops epilepsy, or Drum V.I.'s exhibits a serious case of the Keith Moon's) during regular playback / Print To Track / Realtime Bounce - Pro Tools instead gets everything bang on the mark with Offline Bounce (which makes sense, but doesn't speak too reassuringly of Realtime accuracy). |
Bounce to disk in only one channel | rennman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 10-12-2012 01:03 PM |
Bounce to Disk sounds bad... | mahler007 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 10-05-2004 12:58 PM |
'bounce to disk' for master mixes or not? | bruceup | Tips & Tricks | 24 | 01-19-2004 05:08 PM |
Bounce to Disk/Master Fader | stut5 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 11-24-2003 03:49 PM |
Master X kills bounce to disk | SteveGarman | Pro Tools TDM Systems (Mac) | 4 | 04-02-2002 09:23 AM |
