Go Back   Avid Pro Audio Community > Pro Tools Hardware > FireWire & USB Audio Interfaces (Mac)
Old 04-22-2013, 04:16 AM
Riccardo Riccardo is offline
Default can I connect mac and pc simultaneously?
I recently bought a Mbox 3 pro, and I'm using it connected to a macbook pro (with pro-tools 9) via a 400-800 FW cable, and a pc (just as an external sound card) via a texas instruments firewire pci-e card and a 400-400 FW cable.
I thought I could connect mac and pc simultaneously and switch between them via software or pressing a button, but it seems it's not possible: if the macbook is connected, the card automatically disconnects from the pc.
do you know if there is a solution?
then... a reseller told me not to connect simultaneously mac and pc to the two firewire ports on the mbox because the firewire controller could damage. is that true? if so, what is the second firewire port for?
thank you.
Riccardo
Macbook Pro i7 2.4Ghz, 8 GB 1333, Snow Leopard 10.6.8
PC i5-750 2.66Ghz, 8 GB 1600, Windows 7 Ultimate 64 bit
Mbox 3 Pro
Old 04-22-2013, 07:20 AM
sunburst79 sunburst79 is offline
Default Re: can I connect mac and pc simultaneously?
I would not try this. You could damage something and as far as I know there is no software function to switch between the the 2 via FW.
Scott
Formerly Hobo Wan Kenobi
Core 2 Specs Page
ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88
Old 04-22-2013, 07:34 AM
DeadAgain DeadAgain is offline
o
For instance: connecting an external hard drive.
Old 04-22-2013, 07:39 AM
so I have to disconnect the PC firewire cable every time I have to work with Pro Tools on Mac.
annoying...
Riccardo
Mbox 3 Pro
Old 04-22-2013, 08:22 AM
annoying...
Riccardo
Mbox 3 Pro
Why would you NEED to switch at all?
Old 04-22-2013, 09:26 AM
sorry, I'm not understanding the question. my intention is to use to mbox both with macbook and PC. PC is usually connected to the mbox because I use it for everything (music, movies, etc.), while I use the macbook just to work.
I'd be more confortable if I didn't have to disconnect and reconnect the cable every time I have to work.
Pro Tools 10: Can I Put it on both a Mac and PC simultaneously? frankthetank727 Pro Tools 10 7 05-04-2012 09:36 AM
Two C24s simultaneously? partisan ICON & C|24 12 06-13-2006 09:37 PM
Logic and PT simultaneously... Muzoid Pro Tools TDM Systems (Mac) 7 09-13-2003 10:55 AM
Using 888/24 and 888/16 Simultaneously Rail Jon Rogut Pro Tools TDM Systems (Mac) 1 03-27-2003 12:53 AM
16 Tracks Simultaneously? sugarfuzz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 16 07-11-2002 02:39 PM
