Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools M-Powered (Mac)
Old 05-04-2011, 01:10 AM
Liampike Liampike is offline
Default 003+ not appearing in I/O settings
I'm having an issue with my 003+ rack as it's not appearing in the I/O settings for any session I set up.
I recently upgraded from 7.2 to 9 (student corssover from Le). At first it worked absolutely fine but once I used Pro Tools without the rack plugged in it started to have serious problems. Now with any session I open, even those that were set up with the rack in place, the I/O settings are the built in speakers of my mac. There seems to be no way, that I can see, to revert it back to the rack.
Anyone else had this problem? Any help would be much appreciated.
Cheers,
Liam
Channel EQ not appearing Giftofsound Artist Series 15 03-30-2014 05:45 PM
No Midi Appearing In PT 8 Hodaka 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 03-18-2012 02:57 AM
Strike style, kit and mix saves all appearing under settings Ziko Virtual Instruments 17 10-08-2011 07:56 AM
Plug Ins Not Appearing in PT 7.4 lionelcollins 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 12-03-2008 03:42 PM
no waveform appearing Roo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 04-01-2004 11:43 AM
