Recording issues
Hi all,
I'm encountering this issue every now and again with PTLE 8.0.3 Whenever I arm a track, then hit the record button (I use F12), there's a delay of 10-20 seconds before the recording actually starts. I don't think this is a computer issue. I am running Windows 7 Pro with an Intel i5 750 Processor @ 2.67 GHz, 4 GB of RAM. My score on the D-verb test was 199 Dverbs on (if I remember correctly) 40 tracks. Sometimes when I close the session, there's that annoying delay again before I'm prompted to save the file... Any ideas? Thanks! Mony
Voice Crafters www.voicecrafters.com Audio Buzz https://www.audiobuzz.com PT 2019.5 Interface - Focusrite Clarett 8Pre Mac Mini Running OSX 10.13.5 3.1 GHz Intel Core i7 16 GB 1600 MHz DDR3 RAM External 4TB OWC drive |
Re: Recording issues
Check the "recording disk allocation" (or something like that) in the preferences. If it's set to use all the disk space, it may be slow to start recording. Try setting it to 10 mins f.ex. Disk fragmenteation could also cause it, I believe.
Mac mini M2 16GB RAM macOS 13.4.1. PT Studio 2023.6. Topping E30 II DAC, Dynaudio BM6, 2 x Artist Mix, SSL UC1, Control on iPad. |
Again, is the disk very full or fragmented?
Thanks. I think that definitely helped :)
It's a bit sporadic, as in sometimes it does this, and sometimes it doesn't, so I guess time will tell.. At any rate, I defrag my hard drive every month or so (I don't like doing it too often as some people argue it shortens the hard drive's life..). When I checked just now the fragmentation on my C drive was at 7%, and on my D drive (the audio drive) it was 0% fragmentation, so I don't think that is the issue. Thank you! Mony
And the amout of free space?
(By the way, you say "C drive"? Sounds like PC. This is the mac section of the forum, you know.)
Oops...sorry about that. Yes I am using a PC.
There are no space issues at any rate. I have 2 drives with 500 GB each, and neither of them are over 40% usage.
You may want to post this on the PT PC forum since this is the one for Macs
recording issues | jdh | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 09-27-2010 09:03 AM |
issues with recording done on an old 888/24 | JCD | Pro Tools TDM Systems (Mac) | 3 | 01-21-2008 07:37 PM |
Recording Issues | .tel | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 08-14-2006 03:59 PM |
recording issues with 001 and 6.1 | audiokash | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 07-21-2004 11:35 AM |
Recording Issues?!?! | The_Communist | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 06-28-2003 05:35 AM |
