003 Inputs Not Working
I can't get my 003 inputs working. I am hooked up to a Mytek ADC which is connected to my Mac via lightpipe. So normally I track audio through my mic pre then to the Mytek - record as an ADAT track(s). But if I plug a mic into the back of my 003, for instance input 1 and select analog 1 as my input, I get no signal. I have checked the input/output settings, set them to default, etc., but still can not get a signal when going straight into the inputs of the 003. Any help would be greatly appreciated. Thanks.
Re: 003 Inputs Not Working
anyone have any ideas on this? Not sure why these inputs aren't giving me a signal. going bananas. thanks
You leave no info about your system other than Mac, mic and 003. We need more info to be able to help you.
Meantime, a couple things to check would be: - Is your 003 input 1 set to "Mic" (not Line/Inst) - Does your mic require phantom power, and if so is it turned on (on your 003)?
Macbook Pro 15" 2.66 i7, 8GB RAM / 10.11.5 / Pro Tools 12 / Komplete Ultimate / EWQLSO Gold Play Edition / Steven Slate Drums / Logic Pro / Apogee Duet |
sorry... my system is:
mac OSX 10.5.6 2x2.8 Ghz quad core intel memory 8 GB 800 mhz DDR2 protools 003 LE, version 8.0.1 On the front of my 003, I have the mic/DI button lit on all 4 inputs, and yeah, i'm just using an SM58 to test the signal so no phantom power required. I went to default settings on the current session, plugged into input 1 in the back of the 003, input in pro tools is "analog 1" but can't get a signal. thanks for any help! |
This is confusing. What program are you using to record? If its Pro Tools, then you cannot get signal from the Mytec into the lightpipe input of the computer. The audio must pass thru the 003(the Mytec should work fine on the 003 lightpipe input). For inputs from the 003(1 thru 4) try the Mic/DI switch in both positions(only 1 position will work). If you still get nothing, take the mic and cable to the local music store and test them to make sure they both work. If they do, then maybe the 003 is broken.
sorry if there is any confusion.. see above for the recording platform... pro tools 8.0.1 is what i'm recording with....
my optical format is ADAT, peripherals is 003. I have the mic plugged into the audio 1 plug in the back of the 003. i have tried with multiple cables and mics and have taken those out of the equation thanks guys |
MacPro3ghz, 6GB, 10.7.5, PT10.3.2, Digi002 factory/toolkit2/PTIEP, 11R |
ugh.. thanks flommer! i guess it was so counter-intuitive that the light would be off to be active that every time i read that in the setup guide, my brain just made it say what i thought it should say! thanks for that!
003 Inputs 3 & 4 Not Working | Bambison | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 01-21-2011 10:44 AM |
Mic Inputs 1-3 not working since PT8 | cqd | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 11-09-2009 08:14 AM |
Help! inputs 3 and 4 not working | digipants | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 04-06-2008 07:39 PM |
Mic Inputs Not Working. | ghost104 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 05-15-2007 07:04 AM |
Help--AES inputs on 192 not working | ishur | Pro Tools TDM Systems (Mac) | 0 | 04-15-2006 03:29 PM |
