recording issues with 001 and 6.1
hey all,
I'm having some problems with my 6.1/001 setup... it goes something like this... When i hit play on the transport (after arming it and record enabling a track) the transport doesnt record. i see the stop button light up mometarily just before this... the same thing happens when i hit F12 (except faster) I'm using protools 6.1 with an 001 on a p4, 2 (something) gig with 640 ram. Out of 8 or 9 tries the transport will respond the way it is supposed to maybe once... I'm at a loss and hope that someone is familiar with the problem i'm refering to... any insight is appreciated... thanks in advance Kash |
Re: recording issues with 001 and 6.1
Rail just posted this somewhere else a few days ago: Set the Open ended record allocation preference to 10 minutes.
Also, are you using a seperate drive for audio? Paul
Dell Pentium 4 3.0GHz, 800MHz FSB 1GB pc3200 DDR 60 GB Glyph FireWire Digi 001, PT LE 6.1.1 - Screw 6.4! |
Have you checked that your network card is disabled? I had the same problem and when I disabled the network it worked.
/Hylsan |
guys... firstly... thanks for your prompt responses
yep i'm using a seperate drive for the audio files... though the problem remains irrespective of where i put them ummm.. as far as setting the open ended allocation time to 10 minutes.... how would i go about doing that? the system i'm using is not connected to the inter or an intranet so i'm guessing that the net adapters would be disabled anyway right? thanks again for your prompt replies and trying to get me out of this mess Kash |
Recording issues | Voice Crafters | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 10-17-2010 04:13 PM |
recording issues | jdh | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 09-27-2010 09:03 AM |
issues with recording done on an old 888/24 | JCD | Pro Tools TDM Systems (Mac) | 3 | 01-21-2008 07:37 PM |
Recording Issues | .tel | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 08-14-2006 03:59 PM |
Recording Issues?!?! | The_Communist | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 06-28-2003 05:35 AM |
