Old 04-21-2012, 10:44 AM
sonixstudio sonixstudio is offline
Default Anybody hear clipping with the stock Compessor LimiterIII
I am getting lots of clipping when I use even a modest ratio at the most minimal threshold. This is making this plug practically useless for me . Anybody have a suggestion or possibly a better plug to check out. I really like the interface on the plug only reason I still use it when it actually works which is not that often. Suggestions recommendations fix,s workarounds anything that could help. Thank you
Old 04-21-2012, 03:39 PM
WernerF WernerF is offline
Default Re: Anybody hear clipping with the stock Compessor LimiterIII
Bring down the input gain. Plugins don't clip if your gain structure is correct.
Old 04-25-2012, 11:47 AM
formfunction formfunction is offline
Exactly.. I have used this plug a lot, and never had a problem. Could be that you (OP) might try updating/reinstalling. I have had some of those issues before, but cant remember which plugs. ff
Old 04-25-2012, 07:16 PM
There is no input gain on that plug. So I inserted a EQ before the comp just to lower the input gain on the comp but didnt work. Iv been having this problem since HD8 the 9 now 10. Im a audio engineer . If it clips turn it down in digital if its 2thirds up thats as much as I would ever let it be. Gain staging isnt a problem fror me . I keep my tracks at a modest medium output . Unless there is a problem with having the input gain at no higher than 7/10 peak .
The DIGI comp hasnt worked since I first had HD. I just never said anything because I had options in HD now in HDX thats all there is
Old 04-26-2012, 07:35 AM
JNS JNS is offline
Hi. I'm on PT8.0.3cs2 and I had a similar problem when trying to use that plugin as a limiter. I wasn't hitting it that hard at all and when I soloed the track I could really hear the fuzz (good technical term :) ) on it when it was moderately limiting. Like you, I picked another limiter.
Jeff
HD3 Accel with 2-192s(expanded) and Rosetta 800, PT 8.0.3cs2/10.5.8 on 8-core 2.8 GHz. MacPro with UAD-2 Solo/Duo and Magma Expressbox4 chassis, Sync I/O, Midi I/O, Control 24;
PTLE 8.0cs3 on Dual-core 2.3GHz. G5(PCIe), 003R
Can't hear track I'm recording on but can hear all others Durstlaw 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 19 12-14-2022 01:24 PM
How much clipping is good clipping ? jaunmanuek The Drum Room 9 04-12-2010 04:49 PM
best analogue compessor plugins, ISA quality stoogee 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 02-07-2007 11:05 AM
OT: Hear Technologies Hear Back Matt Whritenour 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 08-16-2004 05:58 PM
Let me hear your digi 001,Post your music that you record hear optymusblu 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 05-05-2003 12:52 AM
