Old 08-22-2006, 08:48 PM
delwin delwin is offline
Default Time Shift to change tempo???
I need to up the tempo of a 3 minute stereo pair audio file of a mix from 120 BPM to 155 BPM. Will Time Shift do this? If not, any other suggestions? I run a three card Mix24 TDM system on PT 6.4.1 for PC. Thanks.
Delwin
Old 08-23-2006, 02:27 AM
steve at Your Heaven steve at Your Heaven is offline
Default Re: Time Shift to change tempo???
That is a pretty drastic shift, and I would expect there to be serious changes and/or artifacts in the sound with any [admittedly older] program I have ever heard of or used, unless some company has made a successful algorithm (program) to compensate for those differences in a musically acceptable way.
Even if such a thing exists, you may discover that the musical structure doesn't work with that much change, just compositionally (e.g., a bass line/keyboard background that sounds fine at 120 is likely to sound much too thick or busy at 155).
steve
Your Heaven
Old 08-24-2006, 12:39 AM
Rammelt Rammelt is offline
the only app I've encountered that can do any kind of drastic changes without too audible artifacts is Prosoniq's Timefactory. Version 2 lets you also do dynamic changes to pitch, tempo and formant.
The drawback is, you have to have a separate soundcard if running Pro Tools at the same time.
BR,
John
John Rammelt
Producer / Composer / Post
Hajp AB
old site:
Soundfactory JPR
Elastic time wont let me change the tempo veryphresh macOS 1 01-28-2011 09:33 PM
Help me figure out this crazy time signature/tempo change.. cheeseandpepper Tips & Tricks 5 08-24-2010 03:56 PM
Memory locators and tempo change! also playhead out of time with ADC DJRECORDS Pro Tools TDM Systems (Mac) 1 08-06-2009 05:18 PM
How do I disable time-stretch when I change the tempo? ShootTheMessenger Pro Tools M-Powered (Mac) 2 11-14-2008 03:21 PM
recording tips for time signature and tempo change harryk Tips & Tricks 2 10-13-2006 11:54 AM
