Backup and rebuild of Win10 PT machine
Hi all
I have a PT Windows machine with Windows 10, but because it doesnt have the correct UEFI firmware layout on C: it can no longer do Windows Updates. Its apparently because the format is MBR but should be GPT. I have a lot of software on this machine and it takes me days to set one up from scratch, so i'm wondering if anyone out there has experience with some method for backing up whats on it, reformatting the C: drive to GPT, then putting it all back. Is it even possible or am i stuck with having to rebuild from scratch manually? Any help or tips much appreciated! Thanks David |
Re: Backup and rebuild of Win10 PT machine
Search 'restore MBR partition to GPT' or there's this:
https://social.technet.microsoft.com...n-to-uefi.aspx Scary, so make sure you have a good backup.
PT 2024.3 DP 11.31 VEP 7.x with various VIs NI Komplete Audio 6 on HP Envy 8G i7 Quad Laptop Win11 MOTU 828es ADA8200 MTP-AV on HP Z2 G4 Xeon Workstation Win11 MOTU M4 on MacBook Air M2 2023 Sonoma.4.1 |
I believe Macrium Reflect can do this. Definitely not for the faint of heart. However, I've found Macrium Reflect to be quite reliable and, once you get the hang of it, easy to use.
So, the bios is set as UEFI, but the OS drive is formatted for mbr? I am curious as to how that happened.
There is no way to resolve this I know of. The formatting is contained in the image, so no imaging process would work (that I know of)
pro-tools-pc.com TRASHER Pro Tools Utility(updated 4-11-2024) HD Native, Avid 16x16, Eleven Rack, Focusrite Clarett 8preX, UA Quad Apollo TB. Intel I7 9900k Win 10 |
I don’t know exactly how it happened. Mobo is Gigabyte X99. It seems to be stuck sort of halfway into uefi. I’ll see if I can set the bios back to boot standard instead of uefi...also maybe a bios update may help...
Sent from my iPhone using Tapatalk |
I’ve never been able to find an answer that doesn’t involve reformatting. Looks like that’s the only option...
Rebuild Pro Tools | TrentWilliams | Pro Tools 12 | 21 | 03-27-2017 10:32 AM |
Rebuild my own sound - oh my god | Sir Hannes | Post - Surround - Video | 5 | 04-07-2016 07:15 AM |
Restore Protools from Time Machine backup | Loganguy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 04-26-2010 08:46 AM |
Backup Drive for Time Machine | lwilliam | General Discussion | 2 | 01-04-2009 08:05 AM |
BackUp With OS X Leopard Time Machine | 25ghosts | Pro Tools TDM Systems (Mac) | 15 | 11-10-2008 10:58 PM |
