Space Plugin no longer on iLok?
Hello,
Recently I noticed that the Space plugin no longer is activated on my Avid/iLok account. Though, I never bought the plugin previously (That I know of), I did get to use it when I downloaded it with the Application Manager along with the rest of the stomp box plugins. The other stomp box plugins still work but this one does not. Is that normal? |
Re: Space Plugin no longer on iLok?
No, it should be included in the bundle of plugins you get with the subscription plan. Have you tried to run the latest installer? And before that manually remove the plugin from the AAX plugins folder?
Johan Bejerholm World Studios Sweden Phone +46707773443 |
Yup! I did remove it previously since it kept popping up as an unregistered plugin upon starting up Pro Tools. I only recently reinstalled to give it another try but no luck. Maybe I'll have to reach out to Avid.
Downloaded PT11, ilok no longer works. | Thea | Pro Tools 11 | 4 | 07-20-2013 05:51 AM |
Need Melodyne Plugin 1.0.3 install pkg - No longer at Celemony | smpkeys | macOS | 1 | 12-28-2010 10:05 PM |
plugin demos are no longer available | daslicht | Virtual Instruments | 0 | 11-23-2010 10:45 PM |
Plugin no longer on drive, but still shows up in menu in LE | mathiasriffman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 06-11-2008 11:15 AM |
PLUGIN MISSING???? Plugin No Longer Active???????? | CF Buck | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 08-27-2006 11:00 PM |
