Plugins no longer render
Hi - all of a sudden when I go to Audiosuite and try and add an effect - no effect. It previews fine and I even get the progress bar like it's processing - but you don't see any visible change to the audio sample (which you normally do) and of course when you playback, there is no effect - reverb, Bomb Factory, delay etc. none of them render. But then when you look at edit menu, you can "Undo" as if it did in fact render. It worked this afternoon when I added multi-tap on delay and I've had mbox-pro LE7 for two years now and never had this happen so I'm kind of stuck.
thanks in advance for any thoughts or solutions. Daniel Leo Simpson p.s. I rebooted a couple times as well and also have the same issue with all my files (songs) not just this one file... - no soap |
Re: Plugins no longer render
Make sure "Use in Playlist" is selected on the plugin interface.
Uninstalled PT and reinstalled entire program - no help Did system restore to yesterday - no help Checked "Use in Playlist" - worked Please come to San Carlos, CA so my wife and I can serve you dinner. Thanks - I never would have gotten it.... Daniel Leo Simpson www.danielsimpson.com |
10.3.2 Bug - Can no longer crossfade clips mid render | JWalkerPostAudio | Post - Surround - Video | 0 | 10-18-2012 12:05 AM |
USB stick no longer seen to install plugins? | voidmix | VENUE Live Sound Systems | 7 | 08-05-2012 09:01 AM |
AudioSuite plugins Render process not good | enisp | Pro Tools TDM Systems (Mac) | 0 | 04-06-2012 04:39 AM |
plugins no longer valid??? | Fitch | Digidesign Hardware & Software | 3 | 06-05-2002 10:15 AM |
Audio Suite Plugins Don't Render! | Superbee | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 03-30-2001 12:00 AM |
