how to have these fat guitar sounds
what i'm trying now alreadt a time is to make these fat guitar sound like fear factory and other metal bands
are there any secrets for it i use bc rich custom shops straight to the bogner amp but what mike's do you recoment for that and what preamps and how to mix please help me that wil be great thanks |
Re: how to have these fat guitar sounds
1. Fat player i.e godd sound to start with
2. good room 3. Royer 121 ribbon mike 4. Some kind of Neve preamp 5 Cranesong HEDD convertor with a little triode and tape sat 6. Cranesong Phoenix plugin Dark Essence with opal setting Hope this helps James Cullen |
Neve may be substituted for UA610......season to taste....
-s0nguy |
hello
yes this wil proberly help so i got a neve 1073 preamp,this wil be good for it i think i wil look for that mike to but how do you put it in fromt of the speaker with the top to the speakers or with the ribbons thanks a lot chris |
Ribbons don't genneraly live long right in front of the speaker cabinet. They should be used as room mics. Try tracking the guitar on one track then play that back into your headphones and play the track again. With the guitar now on two ajacent tracks pan them hard right and hard left. now when you play this back the natural human timing will create a lot of color and thickness. It's how those of us have been doing guitars for many years. You can then use amplitube or some other modeling program to dial in a specific sound but we used to track with a Drawmer 1969 and SM 57's
Try using PZM's on the opisite wall and an SM 57 on the cabinet and a U89 or even a TLM 103 at about two feet from the cabinet. put them all in different tracks and blend to suite. |
A Royer 121 can live in front of a 4x12 just fine (have done it lots), and if you buy one new, the policy used to be that your first re-ribboning was free. There's nothing like two Royers in Blumlein in front of a Guytron......
I would certainly not subject a 4038 or similar (or even the original B&O that the Royer shape was modeled on) to the same torture...if I remember correctly, the Royer goes to something like 120 db.... Hope that helps..... S..
"it's not about making the changes, it's about playing ideas in time" Scofield... |
Track the part 4 times as tight as you can get the guitarist to play. 57 about 1 inch from the cloth. Move the mic closer to the centre of the cone for more brightness or nearer the edge for a more mellow tone. Keep some mid frequency in the sound so there is room for the bass. Don't just scoop all the mids because there will be no tone. Use a frequency concious compressor afterwards to control the low end to taste. This will stop any booming. The bass guitar can be quite important in getting the guitars sounding good. Often it is good to record the bass after guitar to make sure the sound is right with guitars. Now pan 2 guitars hard left and right and the other 2 slightly in from that. Good luck.
Mac Mini M1 16 GB OS 12.7.4 PT 2024.3.1 |
JCM800(1986), Mesa-Boogie 4x12 rectifier-speaker+ SM 57....awesome!
marshall 1960s lead cab. jcm800 head. great set up with a 57. I recently did this on a project and got great results...took two b52 stealth series cabs and had them facing eachother, about 1 1/2, 2 feet apart. each cab was miked with an sm57 then a audio technica 4050 mic (or anyother large cndenser mic) in the center between the two cabs. having the 3 tracks gave me ALOT of control over the tone. i did this with a hardcore band, so you may want to try it.
Guitar Sounds Different when Reamping! | SixStringMadness | Eleven Rack | 2 | 08-26-2013 11:09 AM |
Best way to get guitar sounds? | Robbie Hollywood | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 8 | 09-21-2007 11:02 AM |
Guitar Sounds | copper | Tips & Tricks | 2 | 07-05-2003 11:26 AM |
Guitar sounds | copper | ICON & C|24 | 1 | 07-04-2003 10:15 AM |
guitar sounds...... | jimmyzee | General Discussion | 52 | 10-30-2002 10:32 PM |
