HELP: Skype setup for remote ADR
We receive an inquiry to do a remote ADR session with Skype screen sharing (no source connect). Could anybody assist in how to properly setup the routing, in order so they can listen through our Studio Mic and their comment can be heard by the actor. Any help will be appreciated. Thank you.
Satrio Budiono FourMix JFS Mac Studio Max M2 (2023), 32GB RAM, Ventura 13.6.4, PT Ultimate 2023.12.1, Sonnet TB2 III-D, Avid HDX 2, Sync X, MTRX Studio, Trinnov D-Mon, JBL 708P, 705P & JBL 3635 (Atmos HE 7.1.4) |
Re: HELP: Skype setup for remote ADR
You will need a software like Source Nexus to route audio into and out of Pro Tools.
iMac Pro - MacOS 10.14.6 --- - Pro Tools U HDN 2019.6 - Avid HD Omni + HD I/O 8x8x8 - C|24 | S3 | Dock |
Loopback might work as well. I think you might have to set up an aggregate device in order to get in/out of ProTools. Definitely Source Nexus is the most full-proof way to go, but a little pricey.
I would advise using a secondary computer just for the skype connection and utilizing a mono input an output from pro tools to send and recieve from skype.
Hi All,
Thank you for all the input. Considering the Source Connect-Nexus option, we don't need the SC Pro right? And since we still going to need to have a Skype screen sharing session (the clients is in multiple location), How we integrate the video/webcam? Again, many thanks for helping.
Again. I highly recommend using a different computer for Skype than you do for ProTools. If you insist on using the the same computer for both be prepared for possible computer resource issues.
You will need an external camera (usb or FireWire) for Skype. Your video source for Skype can then be selected within the preferences. |
I'll figure all the great suggestion. Will be back with the result.
Thank you all.
You can also use the optical SPDIF out of the 192 into the Spdif input of the Mac.
I use Nexus too (my SPDIF isn't working any more) but I find it introduces a lot of latency. |
Hi All,
Just to recap from our session. We finally purchased the suggested SC Nexus and set it up on our PT system. We run one instance of Skype session with screensharing (mirroring our second display) showing the guide picture (no cam), along with the audio (from the talent mic and talkback). We run another Skype session on an iPad (muted) in the recording booth, just so the client can see and interact with the talent. The session when well and run reliably--although with noticeable latency and some noise/sound gating (but we're not sure, is it the Skype compression or other factor). Again thank you for all your help and advice.
remote mixing through skype or others | Nightworker | Pro Tools 10 | 0 | 11-11-2011 09:53 AM |
PT 7.4.2 + Novation remote 37SL controller setup | marcioguitar | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 10-31-2008 12:17 PM |
Remote setup controller | Bender | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 01-16-2007 04:18 AM |
Help with Skype Setup, Recording with Headset, etc | fmckinnon | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 07-11-2006 08:52 AM |
adat extender for remote computer setup | quincygriffin | Pro Tools TDM Systems (Mac) | 0 | 12-09-2004 04:10 PM |
