Old 09-07-2017, 01:59 PM
colinmansfield colinmansfield is offline
Default PT 10 & Hybrid 3 L-R balance
I recently bought the AIR Hybrid 3 bundle for use in PT 10.3.10 (Mac Pro 5,5, Mac OS X 8.5). All works fine, except that the audio output of Hybrid is balanced mostly to the left on all patches no matter how the pan controls within the patches may be set. Am I alone in this?
I contacted AIR help, but they could offer no solution (so far) except to say they that "[...] this seems to be an issue with how your audio is set up within your DAW." They then suggested I go to Avid's contact support page, but it seems I must pay Avid to open a support ticket, something I would hope to avoid.
I would appreciate any help offered, including workarounds if necessary.
Colin Mansfield
Bandcamp
Soundcloud
Old 09-08-2017, 09:24 PM
Default Re: PT 10 & Hybrid 3 L-R balance
Hmmm, never seen that here. I would check a few other instrument plugins to make certain that its ONLY the Hybrid that sounds off. If it still is, I would start by uninstalling it, downloading the newest version and re-installing
Old 09-09-2017, 11:05 AM
Thanks for the response.
The only other instrument I had this problem with was Kontakt 4 (but not all instruments in K4 showed the problem). NI said it was a bug, and offered the workaround of turning off the "Accept standard controllers for Volume and Pan" in the Instrument Options window (which works).
I bought Hybrid (plus Riser and the AIR effects) as a bundle only a couple of weeks ago but I shall check to see if there is a newer version.
- Colin
Propellarhead balance to work with PT LE 8 akumraza Windows 1 05-02-2013 03:30 PM
Reason Balance himynameisdustin macOS 0 12-20-2012 08:59 AM
rig balance issues Idisagree Eleven Rack 2 03-23-2011 08:46 PM
Balance/Pan problem John Barnes 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 06-04-2007 10:05 AM
Your steps for overall album balance Spiritwalkerpro Pro Tools TDM Systems (Mac) 11 02-17-2007 01:27 AM
