Old 08-13-2013, 09:22 PM
jakedavis jakedavis is offline
Default iLok Sharing Error
I have a more complicated post going about problems that I've been having between Pro Tools, Bluetooth and a new Hackintosh I've built. You can find it here: http://duc.avid.com/showthread.php?p...01#post2070801
But I decided to make a new post with a more general question since it's the point I've now reached as my main consistent problem.
Upon booting up my computer, I get this error:
"iLok Sharing Error
An iLok cannot be shared across multiple operating systems or computers. Disconnect and reconnect your iLok when switching to another OS/Computer."
I've googled the error and it doesn't come up verbatum anywhere, which is really unusual. Has anyone else received this and/or gotten it to go away and/or know what it is referencing? I only own one iLok.
Old 08-16-2013, 01:46 AM
lumcas lumcas is offline
Default Re: iLok Sharing Error
Same problem here, I just disconnect the iLok, reconnect and PT and other iLok software works...but what a mess this whole iLok situation is!
Old 03-25-2015, 05:51 PM
James Jett James Jett is offline
I just started getting the same message once I downloaded Pro tools 10.
I am looking for a solution also. It doesn't seem to affect Pro Tools functionality, but I just installed it and haven't played with it much.
Hope this thread is resurrected and gets some new interest and some answers to this problem.
Old 03-25-2015, 05:59 PM
Craig F Craig F is offline
sounds like the is Virtual Machines are in play
but you scene none of you provided any real system details, good luck with that
Thank you,
Craig
Old 03-25-2015, 06:31 PM
dr_daw's Avatar
dr_daw dr_daw is offline
I've experienced this as well, but it made sense, as I use USB 3 test drives for ANY update. Therefore, when I boot off that drive I would receive that message, unplug and plug in my iLok and everything works. In all honesty, it seems like an OSX 10 problem.
MBP i7 2.6gh, 8g, OSX 10.10.*, PT 11.3.* and PT 12.
Actually happened on a spare iLok and just disregarded it. I suggest you do the same.
FBR recording - https://www.facebook.com/fromthebase...cordsrecording
@FBRrecording - Instagram
Rig
MBP 15" High Sierra 10.13.3, i7 2.6Ghz, 8Gb DDR, 750Gb 7200rpm, PT 2019.5, Focusrite Saffire Pro 40, Octopre MkII, Glyph GPT50, Avalon 737sp, AMS Neve 1073's, API 512c, CAPI 312's, DW drums, Fender Guitars/Amps, AKG, Rode, Sennheiser, Neumann U87 & KM184's, Coles 4038, Equator D5 monitors
Old 03-26-2015, 10:39 AM
I see this message on my Windows machine if I run PT, shut down and swap system drives, and reboot(like I might do to try new software or if I need to revert to an older version I keep on spare drives). The reason here is simple. The USB ports happen to stay powered even with the computer shut off, so the iLok "thinks" its trying to connect to a different computer. Either killing power completely, or pulling and replugging the iLoks solves this(many computers leave some USB ports powered for off-line charging of USB devices like iPhones and such).
ilok sharing between 2 computers ronwasserman Pro Tools HDX & HD Native Systems (Mac) 9 03-10-2013 05:10 PM
Ilok on wireless hub, not sharing, anyone got it working? Actionmusic Pro Tools 10 2 11-12-2012 07:13 AM
usb sharing/switching device for use on ilok johnbhoy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 08-09-2009 04:35 PM
ok... so no one bite my head off for this one.....ilok sharing carl_laruso Pro Tools TDM Systems (Mac) 10 10-20-2008 08:42 AM
File Sharing Error PT 6.4, 001 WKJ2006 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 04-22-2006 05:54 PM
