random latency
I seem to be having latency problem.
Im tracking a bass but at times its in the pocket at times its way out. Im not the world best player but I can play better than that. I have played with all the usual settings. I usually mix in 512 unless otherwise needed . Tracking Im at 128 but I can still feel the latency when I play and even more on playback. Iv never had latency problems before, I tracked the guitars just fine now latency is making me unable to record anything even close to in the pocket. Seems and feels like random latency on playback. Iv never felt latency while tracking since the digi le stuff . Im sure its just something I'm not doing correctly but I don't know what it actually is. |
Re: random latency
Get the same thing now and then. Have you turned off delay compensation?
Re: random latency
No I haven't .
I am also tracking sending my actual track through a bus and a effects send off that bus to a native plug. I know all those things cause latency so maybe I should try the most direct approach possible. Iv never had this problem before so it is sort of confuzzleing |
bounced track has 'random' latency' 1-50 ms | Indidog | Pro Tools TDM Systems (Mac) | 3 | 03-31-2012 01:55 PM |
For anyone who is having the random white noise burst / random distortion problem | Philly | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 01-23-2010 04:56 AM |
random new latency issue (digi002, imac G5) | tempest1226 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 06-14-2008 08:30 AM |
-9073 and -6086 DAE Errors RANDOM, RANDOM, RANDOM | mikerica101996 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 11-13-2004 01:08 PM |
Random Latency using Auto Tune RTAS | jamesadam3 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 11-18-2003 07:44 AM |
