How do you synch hits or loops that are in different tempos with the rest of the trac
I saw Russ UK do this on the AIR Users blog, and PT asked him if he wanted a loop he was dragging into a session to be in the same tempo as the track. Does anyone know what I need to enable to use this feature? I'm assuming it has something to do with Elastic Audio.
Mac Mini M1 2020 Mac Sonoma Pro Tools2024 Pro Tools Carbon |
Re: How do you synch hits or loops that are in different tempos with the rest of the
David,
There are some videos that Digi has made explaining these things, located here: http://www.digidesign.com/index.cfm?...0&itemid=27606 Check out the "Pro Tools 7.4" videos explaining Elastic Audio. Other helpful videos for explaining these kind of things can be found in the "Remixing with Pro Tools" series. Hope these help.
Pro Tools 10.3.9, MBP 2.4GHz Intel Core 2 Duo OS 10.6.8 4GB/Ram, 7200RPM 750GB Internal HD, Focusrite Saffire Pro 40, Digidesign Mbox 2. It is what it is... ScrewMakerMusic |
Thanks, I'll check these out.
macProideo.com and groove3.com have some good EA vids also
-------------------------------------------------- Why do people keep running over a string a dozen times with their vacuum cleaner, then reach down, pick it up, examine it, then put it down to give the vacuum one more chance? |
I checked out the video. Great stuff, and I'm already incorporating the Elastic after watching the video. Thanks again.
Sorry, I meant my last reply for you. Thanks for directing me to the videos. This is great.
Your welcome.
AIR Transfuser Synch Issues with Drag & Drop Loops into Pro Tools 9 | NAJM | macOS | 6 | 02-11-2011 04:03 PM |
trac out of sync when use rtas plugins | raga2000 | Pro Tools TDM Systems (Win) | 1 | 06-03-2007 04:49 PM |
Audio in synch with quicktime, out of synch in FCP | WannabeSQ | Post - Surround - Video | 6 | 09-20-2006 06:47 AM |
Live Dbl Hits loops playing back | Tim R. | MIDI | 0 | 07-08-2005 09:13 PM |
Acid tempos for loops created using Protools? | efiddler | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 08-26-2003 11:41 PM |
