Old 08-09-2001, 12:09 AM
VividMax VividMax is offline
Default Big Hard Drives
Just wondering if anyone knows if there are any disadavantages in using a 50gig or more hard drive with Pro Tools. Also, how big should the partitions be, if at all.
thanks for your help [img]images/icons/smile.gif[/img]
Old 08-09-2001, 12:16 AM
QuikDraw QuikDraw is offline
Default Re: Big Hard Drives
I use a 60GB 7200 RPM Maxtor. It is a single 60GB partition. I have no problem with it. With large partitions it might take a couple of seconds to enter record mode if you don't select a recording time limit in your preferences. It might take quite a while to defrag larger partitions as well. I defrag while I sleep, so that's not a problem either.
Mike
-- Mike
- MacBook Pro 15.4" (9,1) - 2.3 GHz i7 16GB RAM
- OS X 10.14.1 Mojave / Windows 10 (Bootcamp) - PT running on Windows partition
- PreSonus Quantum 2
- PreSonus Studio 24c
- MBox 3 Mini
- Mackie Onyx 1640i
- Behringer X32 Producer
- PT 2020.5.0 (vanilla)
- Various USB2/3 and Firewire hard drives
Old 08-09-2001, 07:12 AM
staylor staylor is offline
I don't think size is a problem in general. Although certain aspects of ProTools can create slow starts if your drive is one huge partion and you have the option checked to use the maximum available space when recording. You can general eliminate these issues as Quickdraw mentioned by setting a time limit on your recording time or partitioning into smaller partitions.
Personally I recommend partitioning the large drives into 15 - 20gig partitions which will allow a 60 min 48khz/24bit session to fit no problem with room to spare, but keep the cluster size down for drive efficiency. But I have to admit that for audio recording the larger cluster sizes won't matter as much because the file sizes are large. For me it comes down to organization. I like to keep my projects seperated on different partitions, but as Quickdraw mentioned defrag time will be cut down as well.
Hope that helps
Hard drives? delgado 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 12-28-2009 04:33 AM
Portable hard drives vs. desktop hard drives NHH 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 12-02-2009 07:29 AM
SSD (Solid State Drives) Alleviating The Need For Two Hard Drives For PT? epu 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 30 04-13-2009 12:19 AM
Hard drives in LE NeXuS LE 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 08-22-2005 01:43 PM
Hard Drives alonzoslefthand 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 05-24-2002 01:30 PM
