Old 03-18-2004, 08:12 PM
bigcow bigcow is offline
Default Portable Hard Drives
What are the differences between the various removable hard drives on the market. Glyph hard drives were recommended by my pro audio dealer while others have said Maxtor drives are just as good (and more affordable). Also, are there other manufacturers I should be considering?
ProTools LE 8.0.3
iMac
Dual 2.5 GHz Intel Core i5
4 GB RAM
1 TB Seagate External HD
Old 03-18-2004, 09:20 PM
Slim Shady Slim Shady is offline
Default Re: Portable Hard Drives
Search the forum for 'firewire hard drives' - the recommendations remain the same as the last bazillion times this has been asked. Not trying to be rude, just trying to introduce you to the search function. FWIW, I use OWC drives and love them.
Old 03-19-2004, 06:05 AM
where02190 where02190 is offline
While the Glyph drives peform very well, IMHO they are extremely overpriced, and there are many many less expensive solutions that will perform just as good or better.
To be Protools read/write compatible a FW dirve must be a minimum of 7200rpm, and use the Oxford 911 chipset. Any drive that meets these specs will work with Protools generally. Bigger cache and lower seek times are better.
Under 7200rpm drives and those without the Osforad bridge can be used for backup, you jsut cannot run the sessions from them.
Old 03-20-2004, 04:20 AM
musicelect musicelect is offline
I've never had a problem with a Maxtor or Western Digital hard drive. I have had problems with a Pyro 1394 firewire case that you can put IDE devices in. The hard drives I tried in it would have problems mounting and often would make an audible click and then freeze my G4. Very strange and frustrating. The same hard drives work perfectly inside the G4.
I recommend Glyph and La Cie firewire drives. My friend owns a La Cie and it functions perfectly.
www.markproaudio.com
Portable hard drives vs. desktop hard drives NHH 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 12-02-2009 07:29 AM
Portable drives idris Post - Surround - Video 6 03-08-2009 05:44 PM
Portable firewire drives Kevin Canty 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 02-17-2003 02:17 PM
portable firewire drives... 8trackmac 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 11-21-2002 10:41 AM
Portable firewire drives BAJ 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 06-22-2002 06:37 PM
