Re: The Native Truth vs UAD-2quad vs TDM power!
Normally I run with 9 out of 12 processors, but in this test I could squeeze out more plugins with the 11 out of 12 setting.
I have replaced a quad CPU with a W3690 hexacore 3.46 CPU in the Mac Pro but it is not a Hackintosh. 100 percent Apple Mac Pro. You can find them on Ebay.
iMac Pro - HDX2 - Mojave - AVID HD I/O x7 |
Well if you won't accept the fact that it IS a hackintosh, then how about a Frankentosh? LOL
Derek Jones Sound Engineer / Producer / Composer Derek Jones Linkedin Megatrax Recording Studios Megatrax Studios Yelp Page A-list Music Artist Page |
My MacBook pro on the other hand.... It's an a1260 with an a1226 mobo, two HD's, and 6GB of ram. I'll gladly accept it's a frankentosh.
Dell T5810. Harrison Mixbus 32C. Haven't used PT since 2015 and never been happier. |
An example is this http://store.apple.com/ca/configure/...co=MTg2OTQ5OTk Read this system at 5+. k, beside the g-card and the cpu, can you tell me which mark model and which brand the other pieces are from? Mac doesn't produce any hardware, they buy the individual pieces and pieces them together. There's not even mention of what mobo is being used (in 2007 intel were designing and making the mac mobo with TPM and EFI chips to make sure that osx would only run on those. They were off the shelves mobo, but since then I have no idea who makes them). So anyways, all that to say that it's all things that you could have in your 2k pc and unless you actually open the mac pro and they left the brand on the pieces, you wouldn't really know what's in your mac pro and how cheap it is But your's a hackintosh because it's been modified, and not the stock model of when it left apple's stores. |
#16
Dirk from Brainworx chimed in on the GS thread and pointed out that the UAD and TDM version always used 100 percent of DSP load but the native version is dynamic.
I did the test again with really heavy duty EQ settings. 443 AU Instances in Logic and 330 RTAS in Pro Tools.
#17
A hackintosh IMO is "hacking" osx to work on a system that it wasn't originally designed for. It's a thin line, and more than anything probably boils down to the mobo, but IMO its there. Basically can you install osx straight from a stock disc, or does it require a work around (iBoot,multi beast, ect.)?
#18
+1
But now, can we go back to the topic
#19
Hi Firechild,i've been following your thread here and on GS,you gently answer my doubt in a post here at duc,about instaling a uad 2 duo,to save more cpu for the other plugins in PT.I still don't understand (xcuse the ignorance),the uad eats cpu power?The main plan is to left uad2 for verbs and delays,and cpu to other lighter plugs.Lets say my mixes use to use 3 or 4 verbs,1 delay,1 doubler,and lots of comp eq gates tape emu strip emu buss emu some virt instruments ampli simul etc,24 to 40 tracks.I'm about to buy another pc with i7 8 gig of ram w7 64 bit.Would you recomend me to wait and try the perfomance before to buy an uad 2?PT native.
Thanx |
#20
UNLESS you REALLY need those high quality plugins, you have to bite the bullet and buy the card too. But in your case , you are looking from the the DSP point of view not the plugin point of view so don´t buy until you really need those great sounding plugins. But you asked about RealVerb, that´s not one of the great sounding plugins An uad2-quad can run 36 RealVerbs and if RealVerb still exists as a plugin for DigitalPerformer my quess is that you can run at least 200 RealVerbs on a cheap Intel i7 950 CPU. To be fair I have to say I am using an UAD-2 card myself, but it is for the great sounding UAD-2 only plugins, as the UAD 1176LN or the Roland RE-201 echo for example.
More Native Power or more HDX Power? | hatepop | macOS | 30 | 12-11-2013 02:36 AM |
What is power required for HD Native PCI Card? | akhafaji | Pro Tools HDX & HD Native Systems (Win) | 4 | 08-19-2012 07:57 PM |
does the native card add any mixing power? | KenSluiter | Pro Tools HDX & HD Native Systems (Mac) | 9 | 04-04-2012 12:08 AM |
Does PT10 Native eat up more processing power? | jjboogie | Pro Tools 10 | 2 | 01-15-2012 03:16 PM |
waves' native power pack | zzangsoo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 08-29-2001 11:35 PM |
