I/O issue when Recording in ProTools First
Fam,
I have just recently began to play around with Pro Tools First and have been running into a bit of an issue that I can not seem to resolve or find an answer too. When I first downloaded PTF, I was without an interface, so I was advised to install the ASIO4ALL driver, which I did and this worked fine in regards to me getting sound from my lab top, until I purchased an interface. After purchasing my Focusrite Scarlett Solo, I downloaded all the necessary drivers/plug-ins and, at first, was unable get any connection from the Focusrite into ProTools with my instrument plugged in. I solved this by changing the playback engine in the setup tab from the ASIO4ALL to the Scarlett Solo interface. Now I am able to get signal from my instrument when I enable to recording option on a new audio track; however, I am unable to hear the track my my labtop speakers. The only time I get audio play back from Pro Tools is when I change my playback engine to ASIO4ALL. I am assuming this has to do with the fact that I set the playback engine to the Scarlet Solo, but I do not have speakers connected to that interface. To put simply, I want to be able to record my guitar using my interface and want the play back to come from my computer speakers. I have tried setting this up in control panel in the sound setting, but that also did not work. Is this something that I can set up or do I have to have speakers set up to the Scarlett Solo in order to hear the play back from my recording? Thanks in advance for all input! |
Re: I/O issue when Recording in ProTools First
Put an A/B switch between your interface-computer and your speakers. I don't believe you can designate more than one i/o device at a time, or one for input, a different one for output.
Might also consider a Mackie Big Knob or a Presonus Central Station, which is a very elaborate means of doing the same thing. |
Recording timing / late recording issue resolved | DAWgEAR | Pro Tools HDX & HD Native Systems (Win) | 0 | 07-17-2013 09:10 AM |
Latency issue - I'm afraid of recording in protools 8 | amoretam | Pro Tools M-Powered (Win) | 12 | 05-26-2011 04:10 PM |
Recording Issue | abre | Pro Tools M-Powered (Win) | 2 | 07-02-2008 03:17 AM |
Recording time issue, only when recording | Boxingnoise | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 07-18-2006 04:07 PM |
ProTools 5.2 LE Mbox Recording Issue | Alhuero | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 06-27-2003 12:02 AM |
