Using Logic Pro Instruments with ProTools LE
Does anyone know if I can use Logic Pro EXS Instruments with Pro Tools 8 LE on Leopard?
Thanks, Jeff |
Re: Using Logic Pro Instruments with ProTools LE
you can use logic with EXS plugins using Digidesign Core Audio
you CAN NOT use EXS Plugins in Pro Tools But this info is explained in detail within the tech docs portion of this webpage
http://www.studio-techservices.com าำ [email protected]mMitch Berger Tech Services We service ALL Avid products no Problem HD192, 192, Omni, Control Surface, Pre, XMON, 192HD AD & DA / Accel Cards, Everything ALL NEW HD192 AD -DA modification. the difference is incredible... no need to ship the entire unit , fast turn around inquiry using link above Repairs of SSL-Neve- Consoles and Repair ALL Modern & Vintage Gear |
I believe Structure Free is supposed to import EXS instruments. You should give it a try.
You could also purchase Kontakt to play EXS, or you could do what I do and run Logic on a second system and sync it to Pro Tools using MTC. |
Using Logic Pro X Instruments in Pro Tools 11 | Becharax | Pro Tools 11 | 1 | 11-03-2013 11:33 PM |
using logic instruments in PT? | req06 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 07-25-2006 11:18 AM |
How do you get Logic Instruments to | kickit | Pro Tools TDM Systems (Mac) | 13 | 04-28-2005 06:25 AM |
Logic with TDM -> no Audio Instruments? | Kwamix | Pro Tools TDM Systems (Mac) | 5 | 01-18-2005 10:41 AM |
EXS24 and Logic Instruments/plugins in Protools | areurecordings | Pro Tools TDM Systems (Mac) | 3 | 06-08-2004 09:59 AM |
