Mix Minus Diagram for ISDN/Phone Patch
Hello All:
I'm wondering if someone out there who does a lot of this might be able to post a screen grab of the Edit/Mix Windows showing tracks and signal flow (Talent in Studio, sending audio to another Studio). Thanks in advance!! |
Re: Mix Minus Diagram for ISDN/Phone Patch
Source Elements has a template for Source-Connect
http://source-elements.com/documents...nt_Session.zip SC is setup on one aux in this setup.. the input to the aux goes out to the remote connection and the out put of the aux is what is received from the remote connection. SC can send and receive on the same plug-in, if you are using ISDN or phone patch you can break this aux up in to two aux faders (one for send and the other for receive) the basic setup is to create a send that feeds your ISDN, Phone patch, Source-Connect, paper cup and string...... send send everything you want the remote side to hear (talkback, playback, etc) to this send. just don't send the receive from your ISDN, Phone patch, Source-Connect, paper cup and string to this send. (that is the minus part of the mix) hope this helps |
002 Phone Patch | jlr111 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 12-19-2008 09:36 AM |
Routing - Client phone patch / isdn | Steve Brown | ICON & C|24 | 1 | 02-27-2008 11:10 AM |
Mix minus for talkback when patched to other studio via ISDN | djrobbie | Pro Tools TDM Systems (Mac) | 6 | 05-28-2007 08:28 PM |
Phone patch through PC | RobMacki | ProControl, Control|24, Command|8 | 6 | 04-28-2006 04:28 PM |
ADR with ISDN/ Phone-Patch questions | villagesound | Pro Tools TDM Systems (Mac) | 5 | 02-09-2005 09:34 AM |
