Old 04-16-2012, 05:22 AM
jopheza jopheza is offline
Default Eleven Rack Editor Disappearing
Hi there, any help would be appreciated.
Every now and then my 11R loses contact with protools. (have the expansion pack, updated firmware and now running PT LE8.05)
Once it's gone i can't open 11R the editor window in Pro Tools. This is particularly annoying as it editor is now failing to launch with my most common session templates. the 11R works just fine and i can edit settings via the front panel but i can't get into it through PT.
I'm doing a lot of recording with vocalists and i really need to edit the parameters on screen. Any ideas will be gratefully received.
Thanks,
Joseph
Old 04-16-2012, 06:41 AM
Default Re: Eleven Rack Editor Disappearing
Sorted it. apparently you're not supposed to disable other soundcards!
http://avid.force.com/pkb/articles/e...oting/en367487
Eleven Rack Editor - Info Benoni Eleven Rack 61 02-25-2017 11:35 AM
Eleven Rack Standalone Editor brianiac5150 Eleven Rack 315 02-07-2015 04:53 PM
Eleven Rack Editor - Always On Top (Windows) Benoni Eleven Rack 4 01-24-2014 11:54 AM
Eleven Rack Editor Now Available Avid Technical Alerts 0 01-23-2014 09:02 AM
