#21
Re: Crackling when moving windows??
I have confirmed meanwhile that I get crackles when connected, and can consistently make them go away by disabling my NIC.
David J. Finnamore PT 2023.12 Ultimate | Clarett+ 8Pre | macOS 13.6.3 on a MacBook Pro M1 Max PT 2023.12 | Saffire Pro 40 | Win10 latest, HP Z440 64GB |
#22
NIC? network card?:)
I have it disabled already... I do have a USB WIFI connected though... but i dont have any irq conflicts with my usb ports and audio card.. so that shouldnt be a problem |
#23
Can you post a Sandra report and give all the other information requested in the Help Us Help You thread?
#24
Try disabling the Wi-Fi. That's one of the Avid Optimizations you might have missed.
Cheers,
#25
SiSoftware Sandra
Computer Workgroup : WORKGROUP Host Name : Troels-DAW User : Troels Processor Model : Intel(R) Core(TM) i7-2600 CPU @ 3.40GHz Speed : 3.39GHz Cores per Processor : 4 Unit(s) Threads per Core : 2 Unit(s) Type : Quad-Core Integrated Data Cache : 4x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size, 2 threads sharing L2 Cache : 4x 256kB, ECC, Synchronous, ATC, 8-way, 64 byte line size, 2 threads sharing L3 Cache : 8MB, ECC, Synchronous, ATC, 16-way, Exclusive, 64 byte line size, 16 threads sharing Computer Mainboard : Intel DP67BG BIOS : Intel BGP6710J.86A.2053.2011.0818.2322 08/18/2011 Bus(es) : X-Bus PCI PCIe IMB USB i2c/SMBus Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : Yes Total Memory : 3.49GB DIMM DDR3 Chipset Model : Intel Core (Sandy Bridge) DRAM Controller Front Side Bus Speed : 100MHz Total Memory : 4GB DIMM DDR3 Channels : 2 Memory Bus Speed : 2x 667MHz (1.33GHz) Memory Module(s) Memory Module : 0x393930353430332D3138352E4130304C4620 2GB DIMM DDR3 PC3-10700U DDR3-1332 Memory Module : 0x393930353430332D3138352E4130304C4620 2GB DIMM DDR3 PC3-10700U DDR3-1332 Video System Video Adapter : NVIDIA GeForce 8400 GS (8 SM4.0 1.4GHz, 512MB DDR2 998MHz 64-bit, PCIe 2.00 x16) Graphics Processor OpenCL GP Processor : NVIDIA GeForce 8400 GS (8SP 1C 1.4GHz, 512MB DDR2 998MHz 64-bit) Compute Shader Processor : NVIDIA GeForce 8400 GS (8SP 1.4GHz, 512MB DDR2 998MHz 64-bit) CUDA GP Processor : NVIDIA GeForce 8400 GS (8SP 1C 1.4GHz, 512MB DDR2 998MHz 64-bit) Storage Devices SAMSUNG HD502HJ (500.1GB, SATA300, 3.5", 7200rpm, 16MB Cache) : 466GB (C:) SAMSUNG HD502HJ (500.1GB, SATA300, 3.5", 7200rpm, 16MB Cache) : 466GB (D:) LITE-ON DVDRW LH-20A1S (SATA150, DVD+-RW, CD-RW, 2MB Cache) : N/A (E:) Logical Storage Devices Reserveret til systemet : 100MB (NTFS) audio (D:) : 466GB (NTFS) @ SAMSUNG HD502HJ (500.1GB, SATA300, 3.5", 7200rpm, 16MB Cache) Hard Disk (C:) : 466GB (NTFS) @ SAMSUNG HD502HJ (500.1GB, SATA300, 3.5", 7200rpm, 16MB Cache) Optical Drive (E:) : N/A @ LITE-ON DVDRW LH-20A1S (SATA150, DVD+-RW, CD-RW, 2MB Cache) Peripherals LPC Hub Controller 1 : Intel P67 LPC Controller LPC Legacy Controller 1 : T0 B4-73 Disk Controller : Intel Cougar Point 6 port SATA AHCI Controller USB Controller 1 : Intel Cougar Point USB Enhanced Host Controller #2 USB Controller 2 : Intel Cougar Point USB Enhanced Host Controller #1 USB Controller 3 : Intel Renesas Electronics USB 3.0 Host Controller SMBus/i2c Controller 1 : Intel ICH SMBus Printers and Faxes Printer : Microsoft XPS Document Writer (600x600, Colour) Fax : Microsoft Shared Fax Driver (200x200) Network Services Wireless Adapter : Belkin 54g Wireless USB Network Adapter #3 (802.11g (ERP), TKIP, 24Mbps) Operating System Windows System : Microsoft Windows 7 Home 6.01.7601 (Service Pack 1) Platform Compliance : x86 Windows Experience Index Current System : 4.6 |
#26
that was my sandra report... the funny thing is that this ONLY happens in pro tools... i tried disabling my wifi - didnt help
#27
update: it seems to become more evident if i have 7-8 cores available in pro tools, if i set it to 6 or below it is better (but still unusable) - so could it be something with the cpu settings? i have speedstepping disabled.
-and just to make sure: I have NO conflicting irq anywhere. |
#28
I would try dropping it further to see if it improves even more. Considering that you missed that particular step from the General Troubleshooting thread, it makes me wonder what else you may have overlooked. Can you go through that thread again and verify that you've done all the optimizations and troubleshooting? |
#29
Its been a while now so i dont remember what i have read anymore:)
I'll go through it again. And going lower than 4 cores doesn't help. It only gets worse. It seems that between 4-6 cores is the best. But still unusable. |
#30
Can you zip up your AvidLogFiles folder and email it to me at : vi [at] digidesign [dot] com? Please include a link to this thread in the subject or body of the message.
The log files are located at: C:\users\<username>\AvidLogFiles |
Problems with crackling / static when recording (Windows 7) Mbox2 | zorkiii | Windows | 24 | 11-08-2015 08:44 PM |
moving to windows | vonNoblemachine | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 05-01-2008 11:02 AM |
Moving to windows | McGas | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 03-19-2008 03:25 PM |
Mbox and windows xp crackling sound | Jakob Frandsen | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 11-09-2004 05:05 AM |
Moving from Windows 98 to XP | brianpatrick | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 05-03-2003 01:41 AM |
