Midi Notes Doubled
I was just wondering if anyone ran into this same problem. I have a Fatar Studio 90 plus connected to JV880. When I record MIDI, i get 2 notes stacked on top of each other, one is the regular one which I see, the other is hidden behind the original one which is like a circle and a x in it. Do you know what I'm talking about? Thanks
Re: Midi Notes Doubled
Mac mini M2 16GB RAM macOS 13.4.1. PT Studio 2023.6. Topping E30 II DAC, Dynaudio BM6, 2 x Artist Mix, SSL UC1, Control on iPad. |
MIDI MERGE is off. It seems like a midi loop or echo, but I just cant figure out how to get rid of it.
Thanks |
If you're using a combo patch on the Roland this problem can occur because multiple channels will be outputting MIDI.
I'm assuming you're using the 001's MIDI port- try connecting the out of the Fatar to the in of the 001, and then the out of the 001 to the in of the Roland. You'll have to enable midi thru and also record-arm a midi track assigned to the 001's midi out to get the signal back out to the Roland. But that's the correct procedure for cabling a MIDI studio, and if you expand with a MIDI interface down the road, it'll serve you well. |
Here's the setup-
MIDI OUT (FATAR) MIDI IN (DIGI 001) MIDI OUT (DIGI 001) MIDI IN (JV 880) MIDI THRU (JV 880) MIDI IN (PROTEUS) MIDI IN (EMU ORBIT) I dont think I am using a combo patch on the Roland. Fatar suggested that I use MIDI Thru on the 001 but is there one? Thanks |
Doubled midi notes using M-Audio Keystation Pro 88 | gw sound | Pro Tools TDM Systems (Mac) | 19 | 10-31-2010 11:58 AM |
Why Why Why Am I Getting Doubled Midi Notes While Recording??? | epu | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 12-14-2009 04:44 PM |
Doubled midi notes using M-Audio Keystation Pro 88 | gw sound | MIDI | 5 | 09-07-2007 10:14 AM |
RE: Doubled midi notes- Problem Solved | gw sound | Pro Tools TDM Systems (Mac) | 4 | 05-23-2007 08:58 AM |
Phasing/doubled notes in Reason | uno1234 | Virtual Instruments | 2 | 05-10-2006 07:18 AM |
